Go to Post I want my students to learn passion. I want them to care so much about what they are doing that they infect other people with it... be that FRC or anything else. - marshall [more]
Unread 31-01-2008, 15:43
tbd tbd is offline
FRC #1577
tbd is on a distinguished road
ToothGear Sensor
Hello
We tried to work with the toothgear sensor, but it keeps sending us only the signal "1"...
We only wrote a "printf()" command for the toothgear value, and we tried to put it in both user_routines.c and user_routines_fast.c and still it's either always "1" or when we unplug the sensor it sends "0" and after being near a metallic object, it turns to "1" and stays that way.
Can anyone help us?
Proggraming Team
Steampunk 1577
Israel
Unread 31-01-2008, 16:19
Los Frijoles's Avatar
Los Frijoles Los Frijoles is offline
Stormin' Mormon
AKA: Kevin Cuzner
FRC #2062 (C.O.R.E.)
Los Frijoles has a spectacular aura aboutLos Frijoles has a spectacular aura about
Send a message via AIM to Los Frijoles
Re: ToothGear Sensor
Is this the KOP geartooth sensor? Measure the voltage coming off the sensor output (white) and see if it is ~2.68 volts. If it is about that voltage, make sure you do the resistor modification as described in several threads on the subject (use search...I don't know the threads offhand) and it should be fixed.
Community Of Robotic Engineers 2062
Blender totally pwns 3DS Max...
My life is here and here.
Cuznersoft Hardware and Software Development
IR Sensor mechman9113 Programming 9 29-01-2008 16:18
IR Sensor fabalafae Programming 1 19-01-2008 16:53
Sensor Molten Programming 3 17-02-2007 17:43
Sensor or no Sensor For Autonomous mode Kyle1010 Programming 14 22-01-2003 13:10
Sensor Q Brew Technical Discussion 2 10-02-2002 12:48
