Go to Post The horse is dead; stop beating it please. - DonRotolo [more]
Unread 30-01-2008, 20:58
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
toughbox gear/shaft slippage
Has anyone noticed that the drive shaft gear is a loose fit on the drive shaft? That is a bad thing, correct? I guess it will wear over time but it should be a pretty tight fit to begin with, right?. We took a toughbox apart (we have been abusing for a few days testing software) and it was a noticeably loose. But when we went to replace it with a new piece, they are loose also (tried 3 separate gears and shafts). It seems to be designed that way!
Please help a poor EE trying to diagnose a mechanical problem.
TIA
Unread 30-01-2008, 22:53
Team Lucky's Avatar
Team Lucky Team Lucky is offline
FRC #2332
Team Lucky is an unknown quantity at this point
Re: toughbox gear/shaft slippage
HEY YOU NEED TO ROUGH UP THE SHAFT WITH A CENTER PUNCH THEN YOU WILL HAVE A TIGHT FIT WE HAD SAME PROBLEM AT KICK OFF
Unread 30-01-2008, 23:41
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I'd recommend stepping back, taking a deep breath, and then wandering off and working on more important parts of your robot. The small amount of backlash in that joint isn't going to make it meaningfully less sound, nor is it likely to affect any feedback code you have. The toughboxes are relatively inexpensive, but reliable transmissions. The small amount of slop there would be of concern if you were running at very high loads that you were rapidly reversing, but it won't be a problem for 99% of FRC teams. Any teams that would have problems with it would know that re-machining the shafts is your only option. "Roughing" up the shaft will only give you a false sense of accomplishing something. If you're running the kind of loads where the slop is a problem, a few puny dents from a center punch are either going to get flattened or going to gouge out the inside of the gear. Neither helps you out. If you're not running the kind of loads where slop is a problem, them you don't have anything to worry about anyways.
So, short answer, the slop isn't a problem, just a consequence of the low, low price of free that you got the trannies for. "Roughing" the surface won't get you any benefit and might actually be harmful.
Unread 30-01-2008, 23:42
David's Avatar
David David is offline
FRC #1647 (Iron Devils)
David is a jewel in the roughDavid is a jewel in the roughDavid is a jewel in the roughDavid is a jewel in the rough
Send a message via AIM to David
While this may make the fit tighter, it is not necessary. The fit is fairly loose, but does not need to be extremely tight.
Unread 30-01-2008, 23:44
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
I was showing one of our mentors the workings of one of our Toughboxes when he noticed the incredible amount of slop in the gearboxes. He suggested shimming them. We used a 7 mil brass shim on one gearbox, but, strangely enough, the other gearbox wouldn't even fit 4 mil.
This is frustrating because the tolerances on other parts were very tight (e.g., getting the bearing over the output shaft, inserting the roll pin).
Unread 30-01-2008, 23:45
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I know the feeling, but the other way...
Like they said, just leave it alone and don't worry about it. The hex shaft is plenty strong.
Unread 31-01-2008, 16:46
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
OK, I reckon we'll move on. And I understand that you get what you pay for, however the transmissions are anything but free. But we are talking about semi-ridiculous machining tolerances. It is not even close. It seems counter-intuitive that this is 'OK'. Any slippage at all with a new mechanism will accelerate the wear on the surfaces, correct? Its akin to using the wrong size wrench on a bolt.
We have the capabilities to make new shafts but its a lot of mill and lathe time we'd rather spend on other things. The purpose of the query was to see if it mattered enough to try and fix it. Thanks for the all the replies. One team wrote "would be of concern if you were running at very high loads that you were rapidly reversing", the default code (which we are not using) will reverse the robot very quickly and most robots are working with nearly the same load (<140lbs on X wheels) so I'm not sure I get the point. It seems to me that this gear should not be loose. It does not cost anymore to make something the correct size (within reason).
Unread 31-01-2008, 17:27
It does in fact cost more. 4140 hex shaft from McMaster has a -.008 tolerance. Any hex broach you'd care to find is going to have a +something to -.001 tolerance or so. So if you're interested in inexpensive product, you buy the preformed hex shaft, round it off, and worry about something else. If you're worried about fit issues that only matter at the extremes, you buy larger stock, machine a hex on it, and charge a heck of a lot more for the trouble of having to use 2 machines on a simple shaft.
As to the rapidly reversing heavy loads... I'm talking about a 140 lb robot with 2 CIMs per side and ultra grippy tires driving at a top speed of 15 fps across the field and then instantly throwing the motors into full reverse. Repeatedly. And that's assuming the robot stays rubber side down. And even then, I think you're more likely to shear a key, or snap a chain before you ever dent that gearbox. So like I said, not the kind of load commonly encountered by FRC robots, and anyone who's planning on that kind of loading is probably already looking elsewhere for their trannies.
Unread 31-01-2008, 17:46
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
"I'm talking about a 140 lb robot with 2 CIMs per side and ultra grippy tires driving at a top speed of 15 fps across the field" ... thats us we hope but more like 12fps!
We see your point about the tolerances. If we have -.008 on both surfaces, that gets sloppy pretty quickly. And it seems our keys/slots tolerances are contributing the overall slop as well. Adding in the chain tension slop, it is enough to drive the encoders nuts now and then. We have to filter it out.
Thanks!
Unread 31-01-2008, 18:01
David Guzman's Avatar
David Guzman David Guzman is offline
AKA: Dave
FRC #1251 (The Techtigers)
David Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant future
In mass production tolerances can make a HUGE difference in the cost of the product. The kit gearboxes are probably designed to have only the tolerances that they NEED to have. This can explain why some of the tolerances are so tight and others are not.
I agree with what others have said; not worth worrying about it.
Team 1251 The Techtigers
2010 FL Regional Winner (BIG thanks to 86 and 1612)
2009 FL Regional Finalist (BIG thanks to 79 and 744)
2008 FL Regional Winner, FL GM Industrial Design, SC GM Industrial Design
2007 FL Regional Winner, FL GM Industrial Design, Palmetto Regional Finalist, Palmetto Motorola Quality.
2006 Palmetto Regional Winner, Daimler Chrysler Team Spirit Award
2005 FL Regional Judges Award, FL Regional 3rd seeded and finalist, Palmetto Regional Xerox Creativity Award, Palmetto Regional 1st seeded and finalist
2004 UCF Regional Rookie All-star Award
Unread 31-01-2008, 20:05
7-11number1 7-11number1 is offline
ROAR.
FRC #1711 (RAPTORS)
7-11number1 will become famous soon enough
Thanks!
This is a good solid engineering principle. Tolerance errors can add up.
We put hubs from AndyMark onto 8" - Mecanum wheels and they still have slop, but not as much as with chain drive. Also, I have found that after you run the tough boxes for while they tend to mesh a little better and run quieter but the slop remains.
It very important to assemble the tough boxes correctly. There is a star lock washer that holds the little gear in place. Without that the toughboxes will eventually rattle apart inside. Our team forget this washer in ALL 4-toughboxes so we got to assemble/reassemble them multiple times.
Unread 01-02-2008, 12:34
Dick Linn's Avatar
no team (Synergy)
If sloppy fits bother you, you might want to try some Loctite 641 Retaining Compound.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Banebots 1/2" shaft encoder for Toughbox? MrForbes Electrical 11 24-01-2008 21:40
Matching a Gear to Keyed Shaft of DC Motor Spindle Motors 9 22-05-2005 20:23
Window Motor Output Shaft Spur Gear Specs archiver 2000 1 23-06-2002 22:56
Connecting new gear to shaft? mnkysp6353 Technical Discussion 10 29-01-2002 05:12
