Go to Post To help keep the kids on top of their game, I remind them that the school board considers a grade of 97 an A , so we can lose 3% of the kids and still be considered excellent. - DonRotolo [more]
Unread 30-01-2008, 23:34
windell747 windell747 is offline
FRC #2477
windell747 will become famous soon enoughwindell747 will become famous soon enough
Multiple Interrupts
Hi, I was thinking of having and interrupt for the rising and falling edges from the geartooth sensors on each of two wheels as well as have a timer interrupt for each of three SONAR sensors. How do you program different interrupt handlers so that each one responds to a different interrupt from each device?
Thanks,
Windell
#2477
Unread 30-01-2008, 23:50
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Multiple Interrupts
You only have one interrupt handler for your entire program. To handle multiple interrupts, you put a large amount of if-else statements in your interrupt handler to check for which particular interrupt you're handling at the moment, then you do whatever you need to inside that particular if-else statement.
Unread 31-01-2008, 00:00
FRC #2477
Ahh I see what you mean. Are there any examples that you can show me?
Thanks,
Windell
Unread 31-01-2008, 00:29
Kevin Watson's encoder software is a good example of multiple interrupt sources being handled.
http://www.kevin.org/frc/frc_encoder.zip
Many of his other utilities, such as the adc and pwm replacements, are also useful examples.
Unread 31-01-2008, 13:49
JohnC's Avatar
JohnC JohnC is offline
my other name is nigel
FRC #0360 (360 Revolution)
JohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the rough
Send a message via AIM to JohnC
I just had a bad idea. If you want interrupts on the rising AND falling edges...
void Int_1_ISR(void)
	INTCON2bits.INTEDG2 = !INTCON2bits.INTEDG2;
Mmm, does anyone smell the processor cooking?
What place are we at? ... TODAI!
Unread 31-01-2008, 16:41
Racer26 Racer26 is offline
Kevin would definitely be the one to ask, but i think that might work, if you also disabled the interrupt, then made the INTEDG2 change, and then reenabled it.
Alternatively, if you want rising and falling edges, just use the PORTB ones (Int3-6).
Unread 31-01-2008, 16:52
Kevin Watson's Avatar
La Caņada High School
FRC #2429
I did this for the 2004 IR beacon receiver and it works just fine (and no smoke or flames <grin>).
-Kevin
Kevin Watson
http://kevin.org
Unread 31-01-2008, 22:00
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
I have been trying to get Interrupts 2 and 3 working that would be on pins 1 and 2 of the Digital Inputs. I have the code and I seem to get in an infinite loop on the left gear tooth sensor. . . The interrupt keeps going and makes both the right and left gear boxes go full 254 forward.
Right GTS doesn't work at all. (yes we have tested the GTS after we fixed the resistors problem and it works fine)
Can someone see where I messed up??? Copied the code from Kevin Watson's Encoder Code.
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Unread 01-02-2008, 00:37
FRC #2429
I can't really make out what's going on, but I did see that you were calling printf() in your interrupt service routine, which can cause problems. A much better quick-and-dirty way to signal the outside world is to just send a single character using Write_Serial_Port_One(), which executes much faster. It's as simple as this:
Write_Serial_Port_One('*');
Fix this one problem and let us know if it works.
-Kevin
Kevin Watson
http://kevin.org
Unread 01-02-2008, 01:59
Gamer930's Avatar
AKA: Justin
-Kevin
I originally had no printf's and was having the problem. Then added them in to see additionally what could have been causing problems.
Unread 01-02-2008, 03:08
FRC #2477
I was unaware of a resistor problem. What is the problem that you speak of?
Unread 01-02-2008, 13:47
Gamer930's Avatar
AKA: Justin
Team Update #6 explains it. There are a bunch of discussion here on ChiefDelphi about it also. . . Pretty much they switched R3 and R4 on one of the Gear Tooth Sensors
Unread 02-02-2008, 19:03
Gamer930's Avatar
AKA: Justin
I changed all the Longs to Ints
Took out the printf in the interrupt function.
And everything started to work!!!. . . With making those few changes the above code works for Digital Input 1 and Digital Input 2 Gear Tooth Sensors.
It really made me excited today when programming the robot to go *** (A calculated value) gear teeth (8 ft) forward it actually did.
Unread 03-02-2008, 03:52
FRC #2477
whoa! Congrats! I'll be sure to remember that when I get around to the closed loop feedback.
Hosting multiple sites in multiple VMs EHaskins Website Design/Showcase 6 22-12-2007 01:09
Interrupts JSonntag Programming 1 14-01-2006 12:43
timers/interrupts Anton Programming 1 17-02-2005 08:42
Interrupts CyberWolf_22 Control System 3 12-01-2004 21:46
