Re: Different sprockets on front and back wheels
yeah they are the same diameter
If you have 4 motors controlling each of those 4 wheels, then it would be possible, but other factors would have to be addressed to keep your wheels moving at the same speed.
I'm afraid I don't recall who posted it, but there was a thread in which a "NASCAR" chassis set up was discussed (maybe M Krass recalls it). I believe it was based on a 6 wheel chassis, with the front pair of wheels slightly larger than the center pair of wheels which were in turn slightly larger than the rear set. I believe the concept was that since two of the three pairs would tend to be slipping, that they would tend to be able to move sideways somewhat easier (think of a rear drive car. when the drive wheels are spinning, the rear of the car is very easy to push sideways). It may be that a 4-wheel drive system with the front and rear running on different sprocket sizes would be somewhat easier to turn . I would agree that it would essentially be only a little better than a 2-wheel drive system in terms of pushing power.
I'm not too nerdy or anything. Honest. |
I've been wondering if some team would implement Dr. Joe's suggestion. Maybe this is the year. |
| Extra gearboxes needed, KOP sprockets and wheels available in Suffolk County, NY | dmlawrence | Kit & Additional Hardware | 2 | 07-01-2008 10:24 |
| pic: (Real) Robostangs Team 548 FRC 2007 Wheels & Sprockets | robostangs548 | Extra Discussion | 6 | 03-02-2007 11:46 |
| [OCCRA]: question about IFI wheels and sprockets | Russ C | OCCRA Q&A | 1 | 30-09-2006 14:13 |
| pic: Team 207's front wheels | Metalcrafters | Robot Showcase | 7 | 22-02-2006 15:46 |
| Good or bad: back wheels coming off the ground | Gui Cavalcanti | Technical Discussion | 2 | 17-03-2002 22:09 |
