Go to Post As for the rain... I got to test out my umbrella hat last year. Turns out, it actually works...until the wind blows it off. - Barry Bonzack [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 22:59
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
programming
Posted by Charles Elwood.
Engineer on team Bees from Morrisstown High School sponsored by IPT.
Posted on 2/2/2000 8:47 PM MST
I have a question. Suppose I have a motor attached to PWM1 and when you push the joystick on Port1 forward, the motor moves clockwise.....okay now suppose I add some code so that when I push the joystick forward the motor will now move in the opposite direction.
Thanks
charles Elwood
#0047 (ChiefDelphi)
Re: programming
Posted by Jerry Eckert.
Engineer from Looking for a team in Raleigh, NC sponsored by .
Posted on 2/2/2000 10:22 PM MST
In Reply to: programming posted by Charles Elwood on 2/2/2000 8:47 PM MST:
: I have a question. Suppose I have a motor attached to PWM1 and when you push the joystick on Port1 forward, the motor moves clockwise.....okay now suppose I add some code so that when I push the joystick forward the motor will now move in the opposite direction.
: Thanks
: charles Elwood
pwm1 = 254 - pwm1
#0047 (ChiefDelphi)
Programming with solder...
Posted by Joe Johnson.   [PICTURE: SAME | NEW | HELP]
Posted on 2/3/2000 4:46 AM MST
In Reply to: Re: programming posted by Jerry Eckert on 2/2/2000 10:22 PM MST:
OR...
You could just reverse the wires going from the Victor to the motor.
Depends on what you want to do. If you want to see code examples that is one thing. If you really just want to reverse the direction of the motor, flipping the wires is easy too.
Joe J.
P.S. You MAY want to put a few more bits of code in the example given in the message by Jerry Eckert, depending on how paranoid you are about problems with PBasic's 16 bit unsigned math.
I would perhaps write it like this:
pwm1 = 254 - (pwm1 max 254)
This will prevent pwm1 from going wacko if it ever happens to be set to 255 going into the conversion. Also, while I am at it, do NOT do this:
pwm1 = (254 - pwm1) min 0
This will not work as desired. In PBasic, NOTHING is less than 0 so the expression 'XXX min 0' ALWAYS returns XXX. Pbasic has some strange ideas when it comes to math...
[IMG] code is Off
Programming Compatition Angela06 Programming 30 08-04-2005 23:12
multi-bank programming problem GregC Programming 3 14-02-2003 16:13
Pneumatics electrical wiring and programming archiver 2001 1 23-06-2002 23:10
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
pbasic programming punarhero Programming 4 21-01-2002 23:32
