Go to Post A career is never static. - Bill Moore [more]
Unread 31-01-2008, 17:25
bsbllpss's Avatar
bsbllpss bsbllpss is offline
[RockStar]
AKA: RJ
FRC #2044 (Big Red Robotics)
Team Role: Electrical
bsbllpss is an unknown quantity at this point
Send a message via AIM to bsbllpss
chicklet won't work
our team is using a usb chicklet with our control system
everything works fine on it except for one thing
we plug in the power than the joystick and everything is fine
we drive for a little bit as little as one command and then the robot freaks out and starts doing a random command
this is not a programming problem as we plug in the serial joystick and it works fine...continuously
the chicklet only works for about 3 seconds
Unread 31-01-2008, 17:28
bsbllpss's Avatar
[RockStar]
AKA: RJ
Re: chicklet won't work
please help
Unread 31-01-2008, 19:04
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
What joystick you trying to use??
The list of supported joysticks is found: http://www.ifirobotics.com/usb-chick...rted%20Devices
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Unread 05-02-2008, 09:33
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
The behavior you are describing sound like a dead battery. Use a 9 volt power supply or a fully charged battery and this problem should go away.
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
Warcraft won't work, don't knwo why John Gutmann Chit-Chat 2 27-07-2007 08:52
My Chicklet doesn't work r_is_for_ROSER Control System 6 26-02-2007 11:20
Does EasyC Pro work with the USB-Chicklet? lightning_blast Programming 6 20-01-2007 23:39
Major CMUcam issues - LabView app won't work, very low-quality picture scottmso Programming 5 19-01-2006 17:51
3D Studio Max won't work David the bomb 3D Animation and Competition 3 03-03-2004 17:12
