Go to Post ¡viva la weight réduction! - NoSkaOnTheRadio [more]
Unread 31-01-2008, 17:36
JanTM1191 JanTM1191 is offline
AKA: Jan Mariak
FRC #0369 (Nuts 'n' Volts)
Team Role: Driver
JanTM1191 is an unknown quantity at this point
Send a message via AIM to JanTM1191 Send a message via MSN to JanTM1191
Spike fuse
Our team discovered that u can use the auto reset fuse for the spikes. wut u think?
Unread 31-01-2008, 17:42
GRS GRS is offline
FRC #1764
GRS is an unknown quantity at this point
Re: Spike fuse
Only for the air compressors, any other use is against the rules.
Re: Spike fuse
This is specifically allowed for the compressor spike. I'm not sure about the other ones; they may need their fuses.
Unread 31-01-2008, 23:02
Re: Spike fuse
The fuse in the Spike that controls the compressor is the only fuse that may be changed to a 20 amp breaker. The fuse is there to protect the Spike contacts from damage. However, the start current on the compressor is higher than 20 amps for a few milliseconds. That is why this Spike only may have the fuse replaced with a breaker.
Fuse Panel Pnakovich Inventor 4 10-02-2007 15:42
compessor spike fuse blows Nitroxextreme Control System 14 20-02-2005 12:38
compessor spike fuse blows Nitroxextreme Electrical 14 20-02-2005 12:38
Fuse Box Rhs953 Electrical 2 09-02-2004 23:19
picture of 40 amps fuse holder and fuse rcubes85 Technical Discussion 1 13-02-2003 16:03
