Go to Post Nice going guys!! Not only did you succeed in reviving this thread, but you woke up Dave from his mid summer slumber. Now we are going to get 6 months of pre-kickoff torture!! - Rosiebotboss [more]
Unread 31-01-2008, 17:53
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: 1 Joystick Control
Originally Posted by penguain View Post
ok..... Forward goes foreward and backwards goes backwards... But left goes right and right goes left
You can fix this by swapping the pwms on the left side with those on the right. (either through code or switching the pwm cables). However this will make what is now the front, the back and the back is now the front. I think if you swap what's inside the limit_mix function with the one below it, then it'll fix it without changing what's front or back.
Maybe post Your code?
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Joystick control rotated? silliewillie Control System 6 12-02-2005 21:23
We need help with joystick control Team ICE #1611 Control System 4 24-01-2005 15:57
Single joystick control problem Mr. Van Programming 7 23-11-2004 09:10
One Joystick Control KWalsh Programming 4 24-02-2004 17:53
Control System, Joystick mod? Jordan A. Technical Discussion 16 13-02-2002 02:29
