Go to Post Inspiration is a two-way street. - Taylor [more]
Unread 31-01-2008, 16:14
JackknifeJustin's Avatar
JackknifeJustin JackknifeJustin is offline
AKA: Justin
FRC #0388 (Maximum Oz)
JackknifeJustin is an unknown quantity at this point
What are you all using to hold down your control systems?
Help please...
Unread 31-01-2008, 16:18
#1packerfan92's Avatar
#1packerfan92 #1packerfan92 is offline
AKA: Colin
FRC #2495 (The Hamilton Hornets)
Team Role: Marketing
#1packerfan92 is an unknown quantity at this point
Re: What are you all using to hold down your control systems?
Team #2495 of Hamilton West is using plexy glass and wood to mount our control system
Unread 31-01-2008, 16:34
AKA: Justin
Were using Lexan to mount it...is it okay to drill through it and zip-tie the wires down?
Unread 31-01-2008, 16:41
vhcook's Avatar
vhcook vhcook is online now
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
If the "it" you want to drill through refers to the Lexan, sure.
If "it" refers to the robot controller or any other electrical system component, definitely not.
Unread 31-01-2008, 18:10
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
We don't have ours quite finished yet, but when we do i'm sure Rachel will be on here with pictures... Last year ours was simply plywood, screws and zip-ties - very functional, but not very attractive. This year, it's something else entirely
Unread 31-01-2008, 20:42
roborat roborat is offline
roborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to behold
We use Lexan on the bottom to bolt everything to. It is very easy to drill through and light weight. We also make our battery case and air cylinders housing out of lexan.
Unread 31-01-2008, 21:09
in between teams
AKA: Luke Van Oort
Perforated PVC and zip ties. Makes it very easy to swap out components (and faster to put together the board in the first place). Well, I say it makes it easy, but the final board hasn't been built yet. However, the temporary testing board is made from pegboard, which is similar; actually, the pegboard is probably harder to work with than the PVC since it has fewer holes per inch.
We've done plywood, polycarbonate (Lexan), and acrylic (Plexiglas) electrical boards before... acrylic loves to shatter, plywood is kind of heavy (we don't use the really thin plywood, which I imagine is significantly lighter), and polycarbonate can get kind of expensive. Acrylic and polycarb require you to drill holes (<- a big issue with thin acrylic) and mess with those tiny nuts; plywood can just use wood screws (although we usually use bolts for that too).
Team 1219: 2009 - Mentor
Unread 31-01-2008, 21:39
Andy L's Avatar
Andy L Andy L is offline
FRC #1458
Andy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud of
Send a message via AIM to Andy L
We use a lexan box with another piece of lexan mounted vertically on one side. Two big holes in the main box for joysticks and the OI itself mount on the piece sticking out the side.
this year our programmers are making a new one complete with switches, LEDs, and cathodes. They aren't letting out anything more than that until it's done.
a smart thing to do is put velcro on the bottom to make sure it stays. Not sure which side of the velcro is on the shelf where you put your OI. It says in the rules somewhere but I can't seem to find it
Unread 31-01-2008, 21:47
Chris Marra's Avatar
Chris Marra Chris Marra is offline
The Blue Alliance Staff / 177 Alum
no team (TBA / Bobcat Robotics)
Chris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond repute
Perforated Aluminum + zip-ties. We are being very careful with every connection in case crimps or zip-ties fail.
Team 177 - Bobcat Robotics
Unread 02-02-2008, 12:20
Shivang1923 Shivang1923 is offline
I make robot go VROOM VROOM!
FRC #1923 (MidKnight Inventors)
Shivang1923 has a spectacular aura aboutShivang1923 has a spectacular aura about
screws
Unread 02-02-2008, 12:24
Libby K's Avatar
Libby K Libby K is offline
Always a MidKnight Inventor.
FRC #1923 (The MidKnight Inventors)
Rookie Year: 1992
Libby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond repute
Originally Posted by Shivang1923 View Post
screws
Shivang, you win.
Go 1923!
Libby Kamen
Team 1923: The MidKnight Inventors
2006-2009: Founder, Captain, Operator, Regional Champion.
2010-Always: Proud Alumni, Mentor & Drive Coach. 2015 Woodie Flowers Finalist Award.
229: Division By Zero / 4124: Integration by Parts
2010-2013: Clarkson University Mentor for FLL, FTC & FRC
FIRST Partner Associate, United Therapeutics
#TeamUnither | facebook, twitter & instagram | @unitherFIRST
questions? comments? concerns? | twitter: @libbyk | about.me/libbykamen
What 4 functions are you using for autonomous mode? darkpheonix General Forum 8 29-01-2008 23:38
What drivetrain style are you using? Mike Nawrot General Forum 32 27-01-2008 16:32
What tool are you using to make weight? EricH General Forum 40 27-02-2006 19:46
What Motors/Drivetrains are YOU using? IA-Howitzer Motors 16 27-02-2005 15:01
What type of autonomous mode program are you using? SilverStar Programming 1 21-01-2004 18:48
