Team 166 Has Open Sourced Its Code
http://www.sourceforge.net/projects/frst166code08
Team 166 has released its robot code to the masses! Noting that it is still a work in progress (most of it has been tested on test boards and a chassis, which is worth...something), feel free to use it, edit it, and upload new code to the project. Here's a brief listing of stuff in it: -6 kinds of Drive Code, including Mechanum Drive -Code to Utilize EEPROM that has been successfully used for the past two years -Code for our manipulator this year, with OI integrated -Code for the IR receiver -Code for hybrid mode Enjoy! |
Re: Team 166 Has Open Sourced Its Code
I'm sorry to disappoint you, but you should take it off as soon as you can. Your code is based off Kevin's code, which states, in the begining of every file
You could just remove all of Kevin's files and just release the code that you wrote.
Assuming that the 2007 default code available on IFI's website doesn't fall under these restrictions, then our code does not actually include any of Kevin's files. At one point, his adc and gyro code was included and those files and documentation are still in the zipped folders posted for the project, but they have since been removed and the only trace left that they were ever used is a few stray lines that were commented out and never removed afterward.
Removing Kevin's code would be no problem at all, and I'll see to it immediately. Thanks for bringing the issue to my attention -- I clearly didn't think of that. |
Besides Kevin's code, you have two additional problems.
The sourceforge project shows that the project is GPL, but none of your source files contain any reference to the GPL and a copy of the GPL is not included with your source. The bottom of this page tells you how to properly apply the GPL http://opensource.org/licenses/gpl-license.php In addition, since you don't own the IFI code, you can't license it as GPL, so their code should be removed from your project as well. |
A little constructive criticism... I see a lot of logic being implemented in conditional statements that does not need to be. For example:
if(pressure_sensor == 0) compressor = 1;
else compressor = 0;
compressor != pressure_sensor; |
#7
Compilers, not programmers, should do optimizations. ![]() [/tangential rant] |
#8
But if programmers don't know how to do it then who will make the new compilers after this generation retires? Last edited by Tom Bottiglieri : 01-02-2008 at 16:09. |
#9
Thank you for the info about the code we don't own or have the right to redistribute being on the project. All code has been temporarily taken down and we are going to repost *our* code soon.
EDIT: Our chopshop library (CHOPSHOP.C and CHOPSHOP.H) has been uploaded. This library contains our code from previous years (EEPROM, drive algorithms, etc.) that we keep from year to year. More current code will be uploaded once the writers believe that it's ready to release. Again, thank you for notifying us of the licensing issues. Last edited by Eric Finn : 02-02-2008 at 10:40. |
#11
Any code which is published publicly, in a location widely recognized by FIRST teams, is considered COTS and is permitted to be used directly, as per the COTS rules. This allows the use of Kevin's code, or IFI's code, and allows them to update it outside the build season, and all teams to use any version of it. It is my interpretation of this rule, that if you were to have published your code from past years on CD, or on sourceforge and announced it on CD, then that code would also be considered COTS and would be permitted. It is not clear to me: if you were to develop something prior to the build season, and then publish it during the build season, would that still be considered COTS? Unfortunately, in my quick perusal of the rules, I am unable to find the exact rules at this time in order to quote them here. Hopefully someone else can help me out, find them and post them. |
#12
But is it better to have code that reads: Code:
for (samples_recieved=0; samples_recieved<10; samples_recieved++)
for (samples_left_to_receive=10; --samples_left_to_recieve !=0; )
Does this really matter? In most cases, no. But if the code happens to be executing at interrupt level or is executed thousands of time per second then generally yes it does matter. A few changes like this usually can reduce the interrupt code footprint to 1/2 to 1/3 of what it was. Typically I scrutinize only about 10% of the code I write for efficiency, yet the run-time impact can be huge. Knowing the underlying architecture of a processor you're working on also can impact which code constructs you choose to utilize. Yeah, it would be great if the compiler figured out this stuff for you... but often it doesn't or like above can't. On the PIC, for example, computing ram addresses isn't exactly efficient. In some cases if makes sense to unroll "for(...)" loops. For example: Code:
for(ndx=0; ndx<10; ndx++)
sample[ndx] = 0;
sample[0] = 0;
sample[1] = 0;
sample[9] = 0;
![]() PS Another common trick/practice on the PIC when dealing with loading data from h/w such as: Code:
379: timer_count = TMR1H; 380: timer_count <<= 8; 381: timer_count += TMR1L; 382: timer_count -= offset; 06730 50CF MOVF 0xfcf, W, ACCESS 06732 6F17 MOVWF 0x17, BANKED 06734 6B18 CLRF 0x18, BANKED 06736 C517 MOVFF 0x517, 0x518 06738 F518 NOP 0673A 6B17 CLRF 0x17, BANKED 0673C 50CE MOVF 0xfce, W, ACCESS 0673E 6E2B MOVWF 0x2b, ACCESS 06740 6A2C CLRF 0x2c, ACCESS 06742 502B MOVF 0x2b, W, ACCESS 06744 2717 ADDWF 0x17, F, BANKED 06746 502C MOVF 0x2c, W, ACCESS 06748 2318 ADDWFC 0x18, F, BANKED 0674A 5119 MOVF 0x19, W, BANKED 0674C 5F17 SUBWF 0x17, F, BANKED 0674E 511A MOVF 0x1a, W, BANKED 06750 5B18 SUBWFB 0x18, F, BANKED Code:
typedef union u_U16
unsigned int data;
struct {
unsigned char b0;
unsigned char b1;
} u_U16;
u_U16 timer_drift;
384: timer_drift.b1 = TMR1H;
385: timer_drift.b0 = TMR1L;
386: timer_drift.data -= offset;
06752 CFCF MOVFF 0xfcf, 0x516
06754 F516 NOP
06756 CFCE MOVFF 0xfce, 0x515
06758 F515 NOP
0675A 5119 MOVF 0x19, W, BANKED
0675C 5F15 SUBWF 0x15, F, BANKED
0675E 511A MOVF 0x1a, W, BANKED
06760 5B16 SUBWFB 0x16, F, BANKED
#13
Aren't chars unsigned by default on the 3.10 compiler?
#14
Our of our code (specifically that code produced by us) is available now for download either individually or all at once. All code by Kevin or IFI has been taken down.
Our code is now properly licensed, with the copyright statement at the top of each file. You may use it, copy it, and edit it. We request that if you make useful updates to the code (and test them to success), then by all means, please share those updates in this thread. Thanks to all who have posted about issues so far. Whenever you find anything, just post it here. |
| Open-source FRC code | JBotAlan | Programming | 35 | 02-01-2008 03:54 |
| Has anyone posted their autonomous code from 2007? | marccenter | Programming | 9 | 24-05-2007 15:12 |
| Does anyone has code for accelerometer? | sjung9442 | Programming | 2 | 30-01-2006 21:37 |
| Has anyone craked the code yet | Jeremy | General Forum | 2 | 09-01-2004 14:12 |
| Rookie Programmer has question about the default code | DanL | Programming | 3 | 26-01-2002 19:59 |
