For easyC Pro,
how can u get it, so that when the limit switch is pressed and outputting a 1 to the microcontroller, to stop the motor? Right now I have Set PWM3 to 195 Get Interrupt Set PWM3 to 127 which doesn't even make the motor move, at all.... Also, I would like to know how to use the IR board. I'm guessing you'll have to use the interrupt block, which i don't even know how to use. In the end, I need someone to explain the following: -limit switch, implementing it with easyC -the whole Interrupt block, what it exactly does, how can i make it to control a PWM output - IR board, tho I think if i know how the interrupt block works, I could figure this out on my own |
| Limit Switches | ChrisR_522 | Programming | 2 | 25-01-2008 08:04 |
| Limit Switches help | Ianuser | Programming | 7 | 12-02-2007 23:36 |
| limit switches | stephenthe1 | Programming | 28 | 11-05-2005 16:37 |
| Limit switches | Team168 | Programming | 8 | 10-02-2003 16:22 |
| Limit Switches/Pots | Brett W | Technical Discussion | 3 | 28-01-2003 14:25 |
