Go to Post Just remember, a spark of inspiration can produce a lifetime of success. - JoeXIII'007 [more]
Unread 31-01-2008, 22:07
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Re: pic: 1024 2008 Drivetrain - Transmission Closeup
The tensioners themselves are made out of a bicycle part, an aluminum shaft threaded with a die on both ends, and a couple nuts. The bicycle part is the thing that bicycles use to keep their drive chain tight against the rear shifting sprocket. (Link)
It's basically a rubber-ish roller with a groove in the middle and a couple of ball bearings to roll on. This sits on the aluminum shaft, which in turn is double-nutted onto the frame on slots which are somewhat visible (in this picture, the bolt just to the left of the top end of the cutout for the tire. the inboard bolt is not visible from this angle).
If you have any further questions just post.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
pic: 1024 2008 Drivetrain - Underside Qbranch Robot Showcase 6 01-02-2008 14:27
pic: 1024 2008 Drivetrain - High Iso Qbranch Robot Showcase 3 31-01-2008 15:05
pic: 2008 drivetrain 1771 sdcantrell56 Extra Discussion 9 10-01-2008 11:55
Core2062 Look for Drivetrain Motors and transmission Core2062driver Motors 2 15-03-2007 14:46
FRC 2005 Drivetrain and Transmission Parts on Autodesk Inventor 7 KrazyRoadster Inventor 1 23-01-2005 20:29
