Go to Post Did you know that if a G7, G27, G28, and G20 occur in that order at the same time, then the referee will appear to be doing the "YMCA"? :) - Jack Jones [more]
Unread 31-01-2008, 21:59
holty531 holty531 is offline
FRC #2441
Team Role: Electrical
holty531 is an unknown quantity at this point
nason pressure switch wire
question about wiring pwm wire to nason pressure switch...
the pwm cable is the redblackwhite cable right?so, on the nason pressure switch, are we suppose to cut the pwm cable and attatch the red and black to the nason switch? then we plug the other end into the digitol output?
does anyone have a picture i can see? thannks
Unread 31-01-2008, 22:02
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Re: nason pressure switch wire
Yes, cutting a PWM cable and wiring it to a Digital INPUT on the RC would work just fine.
Sorry, no pics, but you would use the red black (Yes, this is an edit, thank you billbo911.. Just changing for accuracy.) and white wires (power (thanks to Don... yeah i really screwed up here ) ground and signal.)
Jacob
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
The switch, as all switches connected to the Digital inputs, needs to be connected between the Black (gnd) and White (signal) wires.
Unread 31-01-2008, 22:18
DonRotolo's Avatar
Back to humble
FRC #0832
Originally Posted by whytheheckme View Post
Sorry, no pics, but you would use the red black (Yes, this is an edit, thank you billbo911.. Just changing for accuracy.) and white wires (power and signal.)
(ground and signal)
Nason Pressure Switch? DPPT1717 Pneumatics 10 09-01-2007 22:31
No value in digital ins using NASON pressure switch. Ari Allyn-Feuer Programming 1 18-02-2006 01:18
Nason Pressure Regulator Calvin_1631 Pneumatics 9 09-02-2006 00:40
Urgent need for Nason pressure switch!! PLEASE HELP! haverfordfords Pneumatics 12 18-02-2005 02:04
Nason pressure switches JP_1163 Pneumatics 11 03-03-2003 23:03
