Go to Post Yes, I have already determined that the device is capable of launching 2,160 Krispy Kreme donuts into the back seat of my Mustang with a vertical displacement of 65 feet, without cracking the sugary glaze on a single donut. - dlavery [more]
Unread 30-01-2008, 21:59
Neurovirus Neurovirus is offline
FRC #0224
Neurovirus is an unknown quantity at this point
Limiting acceleration in easyC
today we let someone besides the drivers/programmers drive and they almost flipped the bot by switching from full forward to full reverse
so i was thinking about limiting the acceleration, namely not allowing switching back and forth between forward and back.
the question is how?
and
is this even a good idea?
Unread 30-01-2008, 22:19
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Limiting acceleration in easyC
How?
Create 2 variables, "Out" and "Old_Out", default them to 127. Store the real final PWM output to Out, and subtract Old_Out, and if the difference is greater than some rate of change (say 50), reset the value to the rate of change (Out - 50). Then set Old_Out == Out, and repeat each loop. You'll have to manage the math a little bit, to prevent exceeding 255 or zero, and maybe elsewhere, but that basic idea is a simple PID loop with only D being used.
Good idea? Maybe not. Driver training is probably a better approach.
Don
Unread 30-01-2008, 23:10
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
We've been using code like that for several years. It not only helps the driver, but takes a big load off the drive train - chains, belts, gears, and reduces the chances of a tripped circuit breaker.
Jerry Skene, mentor OOO OOO 2010 - Chairman's Award- DC OOOOOOOOOOOOOOOOOOOOOOOOOOO
Chantilly Academy, Team 612 - 2009 - Engineering Inspiration Award; Finalist - New Jersey
-----------------------------------2008 - Chairman's Award; Kleiner Perkins Award -Buckeye ---| ---Team Spirit Award - NASA/VCU
-----------------------------------2007 - Chairman's Award - NASA/VCU ---| ---Finalist; Kleiner Perkins Award - Chesapeake
-----------------------------------2006 - Chairman's Award - Chesapeake ---| --- Engineering Inspiration Award - NASA/VCU --
Unread 31-01-2008, 21:39
FRC #0224
@jskene
how did u do it? like how Don R. described it?
Thanks, Don
Neuro
Unread 31-01-2008, 22:40
None #0612
Yes, in a similar fashion.
Unread 31-01-2008, 22:45
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
We've written a "Torque_Limit" function for this year. We can set the max delta for each loop to any value. Out of curiosity, what range have you found to be reasonable? 50, 75, 100 per loop?
Unread 01-02-2008, 08:47
None #0612
We used different values for forward and reverse. We want to be able to stop faster than we can accelerate.
Our acceleration rate was limited to 3, deceleration to 8.
Unread 01-02-2008, 10:10
billbo911's Avatar
Ah, excellent. Thank you.
One more question. Our code works on a change in pwm value per loop. The values you gave seem lower than I would expect. Are your values for change in pwm/loop or loops for a full direction change?
Unread 01-02-2008, 12:38
None #0612
Change/Loop.
It also applies to directional change - forward<--->reverse
Unread 01-02-2008, 12:48
billbo911's Avatar
Change/Loop.
Those numbers are tighter than I assumed they would need to be, but the math agrees.
You can go from STOP to FULL in 1.1 sec. and FULL to STOP in .4 seconds.
Very nice!
How do the drivers like the response?
Unread 01-02-2008, 12:51
scottanderson's Avatar
scottanderson scottanderson is offline
AKA: Scott Anderson
FRC #2608 (MiGHT)
scottanderson is an unknown quantity at this point
We wrote some code for that this year, but then were given advice by a very experienced team that we shouldn't worry about the drive train and that putting a full reverse on the motors is a good way to brake.
The problem with the limiting code is that the robot really doesn't stop very quickly at all when the outputs are just set to 0.
Regards,
-scott
Unread 01-02-2008, 13:48
None #0612
"How do the drivers like the response?"
They don't notice a big difference.
Regards,
-scott
You probably have the "BRAKE" jumper on the Victor set to "COAST".
Unread 02-02-2008, 12:41
AKA: Scott Anderson
FRC #2608 (MiGHT)
You are correct. Thanks for the tip.
What do folks think about the advice we were given about thrashing the gearboxes, though? Was that sound advice, or do we need to worry about adding some sort of intelligent damping to avoid it?
Regards,
-scott
Unread 02-02-2008, 12:50
paulcd2000's Avatar
paulcd2000 paulcd2000 is offline
Accidentally speaks in C
AKA: Paul Dagnelie
FRC #1719 (The Umbrella Corp.)
paulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the rough
Send a message via AIM to paulcd2000
one method we are attempting this year is to use the accelerometer, can actually limit the acceleration itself, instead of just pwm values
"People don't say 'It's just a game' when their team is winning!" -- Scott Adams
5.5 students (on average)* $7/h *210 hours/student= $8085 of labor, all volunteered (not counting mentors', who are each that much)
We have blades on our robot?! ***sweeeeeet***
There are 11 types of people in the world. Those who can read binary, those who can't, and those who say this joke is supposed to be, "There are 10 types of people in the world. Those who can read binary and those who have a life."
Moderating Acceleration / Deceleration Tom Line Programming 7 15-02-2007 13:39
Acceleration Curve EricWilliams Programming 5 01-02-2006 16:27
Kickoff easyC workshop integrated into EasyC help file Dan Larochelle Programming 0 11-01-2006 06:12
Acceleration Sensor Connected, but values are odd.... Leav Electrical 7 04-02-2005 15:28
