Go to Post Inspiration is created by a vision and is reinforced with success. - rourke [more]
  #331   Spotlight this post!
Unread 30-01-2008, 23:24
SuspectZero's Avatar
SuspectZero SuspectZero is offline
2254 Team President
FRC #2254 (Twisted Transistors)
SuspectZero is an unknown quantity at this point
Re: New C18 3.0+ Compatible FRC Code
will the encoder code work with the US Digital E4P-250-250 encoder which is built-in on the Andy Mark Super Shifter transmission? also what kind of output should u expect from the encoder and the gyro?
Team 2254: Twisted Transistors
2007 FRC: Placed 18th in Regionals
2008 FRC: TBD
  #332   Spotlight this post!
Unread 31-01-2008, 00:24
The E4P is a standard quadrature encoder. I can assure you that it works perfectly with Kevin's encoder library for the standard IFI code, and I have very high confidence that it will work just as perfectly with his new framework.
  #333   Spotlight this post!
Unread 31-01-2008, 21:52
JHale JHale is offline
JHale is an unknown quantity at this point
Having the same problem with the new code as someone mentioned before.
When I build the project with Initialize_ADC() uncommented, it builds fine but encounters a code error.
When I build the project with ENABLE_TIMER_4 defined in timers.h, the linker encounters the error:
Error - symbol 'Timer_4_ISR' has multiple definitions.
I have tried commenting out the definition for Timer_4_ISR() in timers.c (because it does nothing) but we get back to the code error. Also, ENABLE_TIMER_4 is defined in ifi_frc.h.
Using a 2007 RC, MCC18 3.10;
Thanks!
-James
  #334   Spotlight this post!
Unread 31-01-2008, 22:48
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
per Kevin's read-me
2) Enable the timer 4 interrupt service routine in ifi_frc.h
3) Make sure timer 4 is disabled at the top of timers.h.
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
  #335   Spotlight this post!
Unread 03-02-2008, 12:38
Kevin Watson's Avatar
La Caņada High School
FRC #2429
I've written replacement code for IFI's Get_Analog_Value() function. It's now included with both builds of the new code on my website. You can also just grab the files and drop then into your project.
-Kevin
Kevin Watson
http://kevin.org
  #336   Spotlight this post!
Unread 03-02-2008, 14:06
Jon236's Avatar
AKA: Jon Mittelman
So, per your documentation, to use your 'quickie' adc code, you shouldn't run them with the gyro code, right?
Jon Mittelman
  #337   Spotlight this post!
Unread 03-02-2008, 14:21
FRC #2429
No, you shouldn't as they'll interfere with each other. You can always just increase the number of analog channels sampled by the adc.c code when using the gyro.
-Kevin
Kevin Watson
http://kevin.org
  #338   Spotlight this post!
Unread 06-02-2008, 19:18
Code Monkey Code Monkey is offline
FRC #1622
Code Monkey is an unknown quantity at this point
I have gotten Timer0 to work as a clock for the code. A few misadventures (like not putting the initialize function in the Initialization.c in Teleop.c), but actually is very easy to implement in the new code with the prescaling.
I have not gotten the encoder 3 and 4 to work. no error messages, but get_encoderX_count always comes back 0. any ideas?
  #339   Spotlight this post!
Unread 06-02-2008, 19:52
FRC #2429
If it builds with no error messages it's probably because you didn't enable the call to the encoder ISRs at the top of ifi_frc.h.
I'm thinking about password protecting the project zip files with a password that's something like read_the_readme.txt_file_before_doing_anything .
-Kevin
Kevin Watson
http://kevin.org
  #340   Spotlight this post!
Unread 06-02-2008, 20:43
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
Okay, I'm having a little more trouble... I'm trying to get some potentiometers working on our robot, so I read the readme and did everything it told me to do:
My comments are in all capitals.
FROM README.TXT
By default the analog to digital and gyro software is disabled.
Perform these steps to get your gyro working:
1) Enable the Initialize_ADC() and Initialize_Gyro() functions in
teleop.c/Initialization(). CHECK, REMOVED THE // BEFORE INITIALIZE_ADC(), LEFT THE GYRO ALONE
2) Enable the timer 4 interrupt service routine in ifi_frc.h CHECK
3) Make sure timer 4 is disabled at the top of timers.h. CHECK, THE // WERE ALREADY THERE, NO CHANGE
4) Depending on the operating modes you will be using the gyro,
place calls to the Process_Gyro_Data() function in the disabled.c/
Disabled_Spin(), autonomous.c/Autonomous_Spin() and/or teleop.c/
Teleop_Spin() functions. DID NOT DO, NOT USING GYRO
5) Add gyro bias calibration code that will execute before you
use your gyro. Example calibration code has been placed in
disabled.c/Disabled() that can be used for the competition (this
requires that you use a mode dongle to emulate the field
controller, which will put you in disabled mode for a period of
time before transitioning to autonomous mode). For testing
purposes you can also use the example code in teleop.c/Teleop()
to make sure your gyro is working. DID NOT DO, NOT USING GYRO
6) Follow the instructions in adc_readme.txt, adc.h, gyro_readme.txt,
and gyro.h for information related to installation and calibration
of your gyro. CHECK, SEE BELOW
FROM ADC_README:
Usage notes:
1) A #include statement for the adc.h header file must be
included at the beginning of each source file that calls the
functions in adc.c. The statement should look like this:
#include "adc.h". ALREADY INCLUDED IN TELEOP.C, CHECK
2) Define the number of analog channels that you'd like this
software to track by opening adc.h and following the embedded
instructions above #define NUM_ADC_CHANNELS. CHANGED THE NUMBER FROM 1 TO 2 SINCE WE'RE USING 2 POTENTIOMETERS, CHECK
3) For advanced users, analog channels can be oversampled to
decrease noise and gain resolution in your analog measurements.
The oversampling ratio can be changed from the default x4
by commenting-out the line #define ADC_SAMPLES_PER_UPDATE_4
found in adc.h and then removing the // from in front of one
of the other options. Measurement range and resolution can be
determined from this table: I'M NOT ADVANCED, SO I LEFT THIS ALONE
ADC Samples Effective
Averaged Bits of Measurement Voltage
Per Update Resolution Range Per Bit
___________ __________ ___________ _________
1 10 0-1023 4.88 mV
2 10 0-1023 4.88 mV
4 11 0-2047 2.44 mV
8 11 0-2047 2.44 mV
16 12 0-4095 1.22 mV
32 12 0-4095 1.22 mV
64 13 0-8191 610 uV
128 13 0-8191 610 uV
256 14 0-16383 305 uV
4) Finally, pick the master sample rate by selecting one
of the available rates found in adc.h. The update rate can
be determined using this formula:
Update Rate =
Sample Rate / (Samples Per Update * Number Of Channels)
LOOKS LIKE YOU HAVE ALREADY DONE THIS USING THIS FORMULA, CHECK
I think I have done everything I needed to do, but when I try to build, it says
C:\Robot Code\2008\ifi_frc_sensor_30\teleop.c:256:Error [1105] symbol 'ADC_CH0' has not been defined
Here is where it is saying this...
liftpos = Get_Analog_Value(rc_ana_in01);
I also tried the quick_adc, but I was having trouble, so I went back to this...
Update: I may have fixed it, but I'm unsure... Instead of Get_Analog_Value(rc_ana_in01), I used Get_ADC_Result(1). Will this work? I'm not going to be able to try this on our robot until Saturday as I'm going out of town for the next 2 days.
Taking a break from mentoring for a few years. (Is that allowed?!?)
Controls Mentor
@rnazaretian
Previous teams:
Team Fusion, FRC 364
Garnet Squadron, FRC 4901
  #341   Spotlight this post!
Unread 06-02-2008, 21:16
FRC #2429
You just use a number from 1 to 16 to select the ADC channel. As an example:
liftpos = Get_Analog_Value(1); or liftpos = Quick_ADC(1);
Of course you'd probably want to #define these values in a header file and then the code would look like this:
// this goes at the top of the source file or in a header file like robot.h
#define ARM_ELBOW_POT 1 // analog input one
#define ARM_WRIST_POT 2 // analog input two
unsigned int elbow_pot;
unsigned int wrist_pot;
elbow_pot = quick_adc(ARM_ELBOW_POT);
wrist_pot = quick_adc(ARM_WRIST_POT);
Because it's simpler, I would use quick_adc() if you're only using potentiometers on your 'bot.
-Kevin
Kevin Watson
http://kevin.org
  #342   Spotlight this post!
Unread 06-02-2008, 21:53
emersont49 emersont49 is offline
#1098
emersont49 is a glorious beacon of lightemersont49 is a glorious beacon of lightemersont49 is a glorious beacon of lightemersont49 is a glorious beacon of lightemersont49 is a glorious beacon of lightemersont49 is a glorious beacon of light
We are using Kevin's code to read the gyro and control our steering. Our steering is connected to a 10K linear pot. We are reading the pot with get_ADC_value and feeding it to a PID function. The intent is to have servo controlled steering.
We are having a lot of trouble getting the servo to respond properly. We are working on tuning our PID loop and having some success.
Here is my question: We are calling the PID routine in Default_Routine so it executes very 26.2 ms. Should we be calling it in a fast loop?
Tim Emerson
  #343   Spotlight this post!
Unread 06-02-2008, 22:21
RyanN's Avatar
RyanN
Thanks again for the help. I found out why the quick_adc.c and quick_adc.h were not working... Even though I said add files to project, it never did copy them to the project folder, like I expected it would... Still getting used to MPLAB. It compiled without any error (just the way I like it ) and I'm going to try it out hopefully Saturday.
Controls Mentor
@rnazaretian
Previous teams:
  #344   Spotlight this post!
Unread 07-02-2008, 14:24
FRC #1622
We had the enables in the IFI_FRC.h. The problem was in the format of the print statement (note to others- output from encoders is a long integer). The encoders were working just fine. Sometimes it really is just dumb stuff. (Thank you Kevin for being patient)
  #345   Spotlight this post!
Unread 08-02-2008, 01:12
sfs sfs is offline
Software Engineer
AKA: Steve Siirila
FRC #2220 (Blue Twilight)
sfs is an unknown quantity at this point
I just tried to build the ifi_frc_sensor project with MPLAB IDE v7.20 and C18 2.4 (had to use the project wizard to create new mcp/mcw files, as I was unable to open the ones that came with). After updating the ifi_frc.h header file to define the proper compiler macro (USE_C18_24), I now am getting these errors:
timers.c:72:Error [1205] unknown member 'PSA' in '__tag_216'
timers.c:72:Error [1131] type mismatch in assignment
Apparently the header file mcc18\p18f8722.h defines T0CON bit 3 as T0PS3, but the timers.c file references it as 'PSA' instead. Should the code read:
#ifdef USE_C18_24
T0CONbits.T0PS3 = 1;
#else
T0CONbits.PSA = 1;
#endif
Does the camera code suits to all versions of MPLAB and C18? razer Programming 3 04-01-2007 14:50
Trying to follow C18 interrupt context code... dcbrown Programming 5 21-12-2006 09:01
Error w/ FRC code JamesBrown Programming 2 08-01-2005 16:17
Programming code Fix FRC Ferazel2001 Programming 6 08-02-2004 02:46
FRC default code hedgehogger Programming 2 21-01-2004 18:41
