Go to Post As JFK said we did not do this because it was easy, we did it because it was hard. - Glenn [more]
Unread 31-01-2008, 21:09
7-11number1 7-11number1 is offline
ROAR.
FRC #1711 (RAPTORS)
7-11number1 will become famous soon enough
Maxbotic Ultra Sonic Senors, Which One
Our team it thinking about using ultrasonic senors for collision avoidance in autonomous mode this year and was wondering which maxbotic sensor would be optimal.
The EZ-2 or EZ-3 have narrower beam widths and it we are reasoning that matching the beam width to the width of the robot 28" is optimal.
Also, it seems the Maxbotix sensors will not require an IRQ handler. You simply pulse them, then wait 50ms and read the analog voltage.
Any comments are appreciated since we have no experience in this area.
Unread 31-01-2008, 21:17
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Re: Maxbotic Ultra Sonic Senors, Which One
i have one, very very easy to use, i believe the only difference between the different types are the range and/or scope of it (i.e. wide range or short long range)
look at the different scopes and see which one you want, dont worry about getting it to work, that part is easy
Unread 31-01-2008, 23:56
I don't think you even have to pulse them. The one we're using acts just like a potentiometer. It connects to +5 and ground, and provides an analog signal.
Unread 01-02-2008, 00:12
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
I can confirm that. The only reason to pulse them is if you have multiple ones, and don't want them interfering with eachother.
Eric Haskins KC9JVH
Webpage intro animation, which one is better? the_short1 Website Design/Showcase 10 18-04-2006 20:41
auto vs. manual loading zone, which one? Liz C Rules/Strategy 44 29-04-2005 07:04
Do the Dew... but which one? OneAngryDaisy Chit-Chat 13 16-06-2003 16:17
FSN Logos - Which One? Jack FIRST Scouting Network 41 26-05-2003 11:01
Which one is the real Dean? archiver 2001 0 24-06-2002 02:36
