Go to Post I would love access to the crystal ball granting you the insight into these changes. - sdcantrell56 [more]
Unread 01-02-2008, 00:26
Keo-san's Avatar
Keo-san Keo-san is offline
AKA: Victor Marmol
FRC #1029 (WolvCats)
Team Role: Driver
Keo-san is an unknown quantity at this point
Encoders 3-6 Trouble
We are using three quadrature banebots encoders with divider kits in interrupts 2, 3, and 4 (we broke off one of the pins in 1 by accident). We are also using the standard Kevin encoder code. Counting for encoder 2 works with no problem but 3 and 4 remain at zero. I switched the encoders on 2 and 3 to see if it was an encoder problem and the same thing happened, 2 worked but not 3 and 4. I've looked around and interrupts 1-2 are different from 3-6 which need the Port_B so I think the problem might be related to that. Thanks a ton for the help!
Team 1029
www.wolvcatrobotics.com
CMU '11
Unread 01-02-2008, 00:50
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: Encoders 3-6 Trouble
I have weird had problems before with the printf statements if thats what you are using to view your data. Save the encoder counts to a variable and print that out instead of the actual function if you can. I had a really weird error that took a couple hours of my time to try and fix...
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 01-02-2008, 03:09
Steve_Alaniz Steve_Alaniz is offline
FRC #2848 (All Sparks)
Steve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond repute
OK, you can't do what you're trying to do. Kevin Watson's encoder code is intended to decode A and B phase from an encoder. The Banebot encoder/divider "interferes' with this process. ( the input at 2 only looks for ONE signal and so "mis-interperts" the signal from the divider as the A phase so you get data).
You have two options, you can either skip the banebot divider and wire directly to the digital inputs. 3 and 13 ...4 and 14 ...5 and 15... 6 and 16 ... this is where the A and B phase outputs go to the SIG pins. you can connect the + and Minus to one of the +5 and Ground pins of the pair. You can do this as long as you don't exceed 1 Amp. Then, you can just use the Kevin Watson code.
If you want to use the divider, you'll have to write your own interrupt code to calculate the count by incrementing or decrementing (depending on the direction signal) on the signals from the divider.
Wish there were an easier solution but I can't think of one.
Oh and By the way, 1(11), 2(12) use a single signal in a 4 state system. 3 (13) and 4(14) use 2 signals in a 4 state and 5(15) and 6(16) detects all 4 states.
Steve
Unread 01-02-2008, 03:15
Keo-san's Avatar
AKA: Victor Marmol
Team Role: Driver
What do you mean by states?
Team 1029
CMU '11
Unread 01-02-2008, 03:26
Ah... OK Quadrature is as it implies, a 4 state system. if you look at the diagrams from the Assembly instructions for the banebot assembly instructions page three shows the two signals in 90 degree phase shift. there are 4 possibilities. Low, Low... Low, High...High, Low... High, High
These are what I mean by states.
Steve
Unread 01-02-2008, 03:30
Keo-san's Avatar
AKA: Victor Marmol
Team Role: Driver
I thought the encoder kits were supposed to 'clean up the signals'....? Does it just do away with the 4 states? or does it obscure them more? I remeber last year we were getting shakey direction readings from these encoders until we put divider kits on them. But they were on the first and second interrupts. and thanks again for the help.
Team 1029
CMU '11
Unread 01-02-2008, 03:41
Yes... you are feeding the A and B phase in and getting a number of states divided by whatever count you select AND a direction signal ( forward or backwards) the Kevin Watson code counts the states and determines the direction so it increments or decrements the count.
I am using two 64 counts per rev encoders on 6 " wheels and going directly into the 5,15 6,16 pins which gives me 128 states per rev. This Works great.
The banebot encoder doesn't really clean up the signal... it's digital anyway. Perhaps you were running too fast and losing counts.
Steve
Unread 01-02-2008, 08:17
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Just a question... are you doing velocity control? If so, I'm guessing you're running in the 39.37Hz (25.4ms) loop? Is this enough resolution?
By my calculations, you can have an absolute maximum velocity control resolution of 0.39ft/sec. Is your robot really really fast? Hence the low res encoder?
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 01-02-2008, 09:04
-q
I'm using the encoders for distance in autonomous mode. The robot is capable of about 8ft/sec at the very top speed. I've run it on short full speed but haven't written the PID coding yet, so I don't know the accuracy just yet, but the simple number tweaking I've done looks promising so I'm expecting really good results from the PID. I'm reading a 6" wheel which in theory gives me a resolution of 6*PI/128 about .15 inch/ count. That's probably more than I need and I hope to have the PID tested and tuned by Monday, I hope.
Steve
Unread 01-02-2008, 09:31
OK I'm brain dead! Sorry, Actually, another solution is to duplicate the 1 & 2 coding for 3 and 4.
In encoder.c cut and replace the interrupt handler for 3 and 4 with 1's (or 2's) interrupt code
void Encoder_1_Int_Handler(void)
	// Encoder 1's phase a signal just transitioned from zero to one, causing
	// this interrupt service routine to be called. We know that the encoder
	// just rotated one count or "tick" so now check the logical state of the
	// phase b signal to determine which way the the encoder shaft rotated.
	if(ENCODER_1_PHASE_B_PIN == 0)
		Encoder_1_Count -= ENCODER_1_TICK_DELTA;
	else
		Encoder_1_Count += ENCODER_1_TICK_DELTA;
#endif
Changin all the 1s to 3s or 4s
so for 3 it becomes
         if(ENCODER_3_PHASE_B_PIN == 0)
		Encoder_3_Count -= ENCODER_3_TICK_DELTA;
	else
		Encoder_3_Count += ENCODER_3_TICK_DELTA;
#endif
The code expects the direction signal on the B pin which for 3 is digital input 13. Since it expects a high or low for direction it just so happens that will work for the signal from the encoder/divider.
I THINK that's the only file you need to change. I'll read through it again but I believe everything else is transparent to the interrupt handler. I can't really est it but it looks right and would be easy to implement. You CAN change 5 and 6 the same way but you mentioned you're only using 3 encoder/dividers.
Duh Me! I was so wrapped up in how I do it I didn't bother to think there was another way even after you mentioned that 2 was working. Hope I didn't throw you off!
Steve
Unread 01-02-2008, 10:15
Keo-san's Avatar
AKA: Victor Marmol
Team Role: Driver
Thanks! We'll try that today at the meeting but it sounds like we're gonna be OK :-) thanks a lot for the help. I'll post back after we try it.
Team 1029
CMU '11
Unread 03-02-2008, 23:40
Keo-san's Avatar
AKA: Victor Marmol
Team Role: Driver
Thanks! its working now. We just have a weird calibration error but that shouldn't be too bad to fix.
Team 1029
CMU '11
encoders benjamin1748 Programming 6 07-02-2007 22:37
Inventor software trouble/ FIRST Base trouble nasa-senpai General Forum 2 24-01-2007 09:15
Encoders Ctx32 Programming 8 13-05-2006 23:54
3 Encoders stephenthe1 Programming 5 17-11-2005 19:21
