Go to Post Everyone is reading way too much into this. The game piece is clearly a bunch of Opahs this year. Problem solved, case closed. Start designing your fish handling robots now. - Ryan Dognaux [more]
Unread 01-02-2008, 10:16
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: pic: Electrical team is so messy
You're just jealous because you can't plumb electrons. =P
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 02-02-2008, 01:15
Jaybee1405
Posts: n/a
General notice to everyone:
Mechanical > Programming > Dirt > Human Players > Electrical
(Mechanical rocks, programmers don't take up space/weight, dirt makes plants grow, human players are at least athletic, and electrical... well umm no comment)
Shutup Kevin, you're just jealous because you can't make an Ackermann steering unit.
Unread 02-02-2008, 02:06
Blue_Mist's Avatar
Blue_Mist Blue_Mist is offline
will return to 766 soon!
AKA: Mika Lai
FRC #0766 (M-A Bears)
Blue_Mist is a jewel in the roughBlue_Mist is a jewel in the roughBlue_Mist is a jewel in the rough
(Mechanical rocks, programmers don't take up space/weight, dirt makes plants grow, human players are at least athletic, and electrical... well umm no comment)...
I do both mechanical AND electrical! Ohhh! Guess that makes me about as average as dirt...
We're doing a vertical board this year. The pneumatics will be on the lower level, next to motors, gear boxes, chain, etc. It'll be neater than last year's, where everything was crammed into a small, compact space less than 12" tall, sharing space with pneumatics and drive train.
And to Jaybee1405, it's a 40-Amp Fuse Panel.
"There's no finer engineering than pit engineering." -kaszeta
"Show a girl how to use a wrench, and she'll put those skills to use for a lifetime. Hand it to her and tell her she's probably better off shopping, and she'll clonk you over the head with it, do your pneumatics system, and CAD the robot." -Amanda Morrison
'09
Unread 02-02-2008, 02:14
Jaybee1405
Posts: n/a
Thanks for that, 40-Amp Fuse Panel. Ok so now my electrical vocab includes:
40 amp fuse panel
RC (thing with blinky lights!)
switch (which I won't forget to push this year and rob won't have to yell at me again at the ruckus)
fans! (ok fine I know they're victors)
spike lee's
big lego block
How am I doing?
Unread 04-02-2008, 20:03
octothorpe's Avatar
octothorpe octothorpe is offline
AKA: Nick Felt
FRC #0766 (MA Bears)
octothorpe is a splendid one to beholdoctothorpe is a splendid one to beholdoctothorpe is a splendid one to beholdoctothorpe is a splendid one to beholdoctothorpe is a splendid one to beholdoctothorpe is a splendid one to beholdoctothorpe is a splendid one to behold
We'll need to make sure that vertical board is securely mounted to the tower. This may be more difficult than you anticipate, given that it'll need to stand off by at least 2 inches and only attach on the sides (the backs of the tower box tubing are where the rollers ride). I guess we can work it out somehow.
What, you mean you didn't like having to stick your hand down into the guts of the robot and fish around to find anything in the electronics?
On a side note, I read this thread last night and remember seeing your post, but I was so out of it at the time that I didn't even realize that it was you, or that it was our robot being discussed... :-/
Unread 02-02-2008, 08:18
65_Xero_Huskie's Avatar
65_Xero_Huskie 65_Xero_Huskie is offline
One T
AKA: Mat
65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute
Is that your ratio to how dirty things are???
Haha.
Min-Max to the Max!
Unread 02-02-2008, 08:47
efoote868 efoote868 is online now
foote stepped in
AKA: E. Foote
FRC #0868
Haha.
then it would be
mechanical > dirt > human player > programming > electrical.
after gojo, everything (except for dirt) would be about equal
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 02-02-2008, 08:54
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Coming from a mechanical guy who probably tried to press in a shaft collar instead of using a bearing. =P
Kevin Li
596 - Sciclones
Unread 02-02-2008, 09:31
merybar's Avatar
merybar merybar is offline
AKA: Matt
FRC #0894 (Chargers Robotics)
merybar is a glorious beacon of lightmerybar is a glorious beacon of lightmerybar is a glorious beacon of lightmerybar is a glorious beacon of lightmerybar is a glorious beacon of light
Send a message via AIM to merybar
For all you mechanical teams out there, you wouldnt be around if there wasnt an dynamic electrical team!!!!!!! LOL
Unread 02-02-2008, 09:41
Torboticsmember's Avatar
Torboticsmember Torboticsmember is offline
AKA: Alan Bartow
FRC #2080 (Torbotics)
Team Role: Driver
Torboticsmember is a name known to allTorboticsmember is a name known to allTorboticsmember is a name known to allTorboticsmember is a name known to allTorboticsmember is a name known to allTorboticsmember is a name known to all
So I guess I would be between mechanical and programming, more on the programming side, because I am the electrical team, or about 15/16th of it, and the programming team, and do mechanical jobs to. So I guess I'm just heinz 57.
But electrical still is the best of all teams
Unread 02-02-2008, 12:00
Jaybee1405
Posts: n/a
You hid the bearings on me!!
Unread 04-02-2008, 20:21
Miner Miner is offline
AKA: Jacob Miner
FRC #2077 (Laser Robotics)
Miner is on a distinguished road
Our mess takes up 1/6th of the shop. Fabrication takes up the rest. I think we have a winner here.
You think thats good? We have a whole corner devoted to electronics! Almost 1/4 of the room.
Unread 04-02-2008, 22:14
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
you think THAT is messy? you obviously havent seen our proto-bot...
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 06-02-2008, 23:35
Jim E Jim E is offline
FRC #1523 (M.A.R.S.)
Jim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond repute
As programming and Electrical mentor for 1523, I must come to the defense of the electronic students. Here is our finished??? board. Yes, wires fly and connectors are trashed. but they are the most important link to the design. Electrons RULE!
http://marsbot.org/index.php?q=gallery&g2_itemId=25157
Team MARS = 1.523 AU from the SUN!
Jim E.
Unread 07-02-2008, 10:31
1086wulf's Avatar
1086wulf 1086wulf is offline
AKA: Ian
FRC #1086 (1086 Blue Cheese)
1086wulf is an unknown quantity at this point
I normally work with mechanical but worked with electrical yesterday. They were actually a lot neater than mechanical. It just depends on if the person in charge makes sure everyone cleans up after themselves. and that pic did not look very messy at all. it would take like 30 secs to clean up
"You sure know how to throw a party. No food, no drinks, and the only babe just left." Dante DMC3
pic: Team 27 Electrical Box Jimmy Holmes Robot Showcase 18 17-02-2006 16:18
pic: Team 1676 Electrical Component Teaser Spiffizzle Robot Showcase 11 16-02-2006 10:35
pic: Team RUSH 27 Electrical Box austind27 Extra Discussion 20 02-03-2005 19:41
pic: Team 93's Electrical box CD47-Bot Extra Discussion 9 12-03-2004 09:46
how messy papa smurf General Forum 21 03-03-2003 02:21
