Go to Post I understand that Dean Kaymen has now invented a super "sniffer" that can scout-out anyone within hearing distance that is remotely-involved with FIRST. - dhitchco [more]
Unread 01-02-2008, 11:24
Aaron_H Aaron_H is offline
FRC #1033
Aaron_H is on a distinguished road
Dead IR Receiver Module
Hey everyone,
We were working with our TinyIR2 IR module that FIRST sent us, and it seems as though the IR module has failed. The symptoms are as follow:
-The board DOES power up
-The board DOES go into program mode (press the button for 2 sec. and release)
-The out0 LED DOES NOT flash in program mode when an IR remote sends a signal.
We tested the remote visually (pulled out the camera phone and shot the IR beam at it...the camera shows a nice purple hue coming from the remote) and even tried several different remotes. I hooked an oscilloscope to the signal output from the IR module and there is no pulse when an IR signal is sent from the remote. We have been running the board from 12V off the circuit breaker panel. Does anyone have any suggestions? Has this happened to you? Also, are there any suggestions for making the ribbon cable more robust?
Thanks,
Aaron
Wiring the IR Receiver Rapt0r9 Electrical 19 29-01-2008 18:42
GPS receiver John Gutmann Technical Discussion 23 01-03-2007 02:35
IR Receiver zachriggle Electrical 7 09-02-2006 17:11
Infrared sensor...receiver emayank Electrical 3 25-02-2005 19:54
How to connect the R/C receiver?! Tim Skloss Robotics Education and Curriculum 7 10-12-2003 16:34
