Go to Post You should never, EVER bully, manipulate, or slander another team for the sake of winning. - Libby K [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 23:01
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
project box
Posted by Justin Stiltner.
Student on team #388, Epsilon, from Grundy High School and NASA, American Electric Power, Town of Grundy.
Posted on 2/5/2000 12:20 AM MST
In the rules it says 'The black project box is intended to serv as a mounting point for the rocker switches, pushbutton switches, and potentiometers used by the robot operators, and to enclose the associated wiring. You may modify the project box in any manner to acomodate your needs.'
does this mean that we MUST use the box only for that or is this just a suggestion? Can we use it on the the actual robot to enclose switches and associated wiring??
Justin Stiltner
Team 388
#0047 (ChiefDelphi)
Re: project box
Posted by Thomas Grupp.
Engineer on team #378, Circuit Stompers, from Newfane High School and Delphi Automotive Systems.
Posted on 2/5/2000 12:08 PM MST
In Reply to: project box posted by Justin Stiltner on 2/5/2000 12:20 AM MST:
: In the rules it says 'The black project box is intended to serv as a mounting point for the rocker switches, pushbutton switches, and potentiometers used by the robot operators, and to enclose the associated wiring. You may modify the project box in any manner to acomodate your needs.'
: does this mean that we MUST use the box only for that or is this just a suggestion? Can we use it on the the actual robot to enclose switches and associated wiring??
: Justin Stiltner
: Team 388
Justin
In my opinion, as long as it was in the kit the box can be used in any way you see fit. That means if you
want to use it on the robot, so be it.
As long as a part comes from either the kit, Small parts or the additional hardware list you can use it ON THE ROBOT!!
Have Fun
Tom Grupp
Team #378
#0047 (ChiefDelphi)
Re: project box
Posted by Lora Knepper.
Student on team #69, HYPER (Helping Youth Pursue Engineering & Robotics), from Quincy Public Schools and The Gillette Company.
Posted on 2/5/2000 8:38 PM MST
In Reply to: Re: project box posted by Thomas Grupp on 2/5/2000 12:08 PM MST:
I'm not sure if you can use it on your machine, but I don't see why not. As for being required to use it, you don't have to. Last year I designed a box out of lexan to mount our switches and other aux. controls. So if you want to get creative, by all means do!
good luck,
Lora
[IMG] code is Off
box grabbing matt111 3D Animation and Competition 3 27-01-2003 23:08
Preseason project AdamT General Forum 4 09-09-2002 00:52
Gray box limitations Tim Skloss Technical Discussion 1 23-01-2002 07:38
MS Project Build Schedule joe_balint Technical Discussion 1 07-01-2002 03:25
Modular Control box assembly Andrew Wyatt Technical Discussion 4 29-11-2001 15:44
