Re: Web-based scouting program
Best regards, Steve |
I have refined it several times over the last year, but that is how it works more or less. It also assumes that each team has an equal chance of competing against each other, which was not the case, as rookie teams always played with better teams boosting their score, and in a few cases the same alliance played together, It still fared very good however. Let me try explaining another way: It takes into account the scores of your opponents and allies. This is the exact SQL query used to find the strength for each team: Code:
SELECT ROUND(AVG(IF(b.teamnum=c.teamnum ,2,-1)*IF(d.alliance="red",e.redscore-e.bluescore,e.bluescore-e.redscore)*IF(b.alliance=c.alliance,1,-1))*100) AS score2 FROM team_match b JOIN team_match c JOIN team_match d JOIN matches e ON (b.matchid=c.matchid) AND (d.teamnum=c.teamnum AND d.matchid!=b.matchid) AND (d.matchid=e.matchid) GROUP BY q.teamnum This is how I get the team strengths. Match predicting is a new area for me, I implemented it just a few month ago. For matches, I found that the sum of the teams strengths on the target alliance, minus the sum of the opponent's alliance, works well enough. I can calculate the chance a team will win with a cumulative logistic distribution, who's parent function is f(x) = 1/(1+e^(-x)). My most recent tests show it is only 80% to 85% accurate, based on how I add the strengths together (add the square roots, etc). I don't really care too much, it isn't the most important part of the program. |
I am looking at it for 1251 as a scouting system
we are attending the florida regional and the palmetto regional If it is useful at florida we will deff use it at palmetto The only thing is that I'm having trouble setting it up could I use access 2007 would that do the same thing as using that other software you wanted to use thanks a lot sebas |
I'll summarize the PM I replied to for everyone else:
There is no reason Access couldn't work, however I can't vouch for it's standards support, and I have no clue how to set it up. It is possible though, since I use a database library (ADODB) that supports many types of databases. I think installing a web server package such as XAMPP or WAMP, which contains Apache and MySQL, is much easier to set up and use. |
Good luck this season! Steve |
| Good program for Palm-based scouting software development? | mbmccormick | Scouting | 4 | 20-01-2008 22:02 |
| IR Receiver 101 web link & an IR based question. | Elgin Clock | Technical Discussion | 5 | 19-12-2007 16:10 |
| scouting program | Marjory Frosty | Scouting | 12 | 21-02-2006 16:30 |
| Scouting Program? | Jeffel | Programming | 3 | 16-02-2005 08:41 |
| Web-Based File Transfer? | Gadget470 | Website Design/Showcase | 6 | 11-01-2004 16:41 |
