Go to Post Finish... what an interesting concept. I'm still hoping to do that to our 2003 bot. - Joshua May [more]
Unread 01-02-2008, 00:22
scottanderson's Avatar
scottanderson scottanderson is offline
AKA: Scott Anderson
FRC #2608 (MiGHT)
scottanderson is an unknown quantity at this point
Strange gear tooth sensor port issue
After a battle with a broken gear tooth sensor, we finally have two sensors working. Good.
We're using MPLab and WPILib, which is nice. However, the problem is that the GetGTSensor code doesn't seem to work as advertised.
The sensors are on ports 1 and 2 of the digital inputs. StartGTSensor(1,0) and StartGTSensor(2,0) work.
However (and this is the weird bit), the values for GT 1 must be retrieved with GetGTSensor(2) and the values for GT 2 must be retrieved with GetGTSensor(4).
Even odder, if StartGTSensor is used with an invert value of 1, GetGTSensor(1) will return -1 once the gear on port 1 starts moving, and GetGTSensor(3) will return -1 once the gear on port 2 starts moving.
What's going on here?
Regards,
-scott
Unread 01-02-2008, 15:15
xrabohrok's Avatar
xrabohrok xrabohrok is offline
hunter of errors
FRC #1208 (The Metool Brigade)
xrabohrok is an unknown quantity at this point
Re: Strange gear tooth sensor port issue
When you say get GTsensor code, is that kevin's code, or your own?
What project are you using?
If it is your code, can you show us it?
"It's programming's fault" may be a viable excuse for just about everything, except the robot falling apart.
It will 'cause it can!
constants aren't. variables won't.
Unread 01-02-2008, 16:01
AKA: Scott Anderson
FRC #2608 (MiGHT)
WPILib's "GetGTSensor" routine, from the latest release of WPILib.
The code is simply this:
void main(void) {
StartGTSensor(1, 0);
StartGTSensor(2, 0);
while (1) {
printf("1: %d 2: %d 3: %d 4: %d\n", GetGTSensor(1), GetGTSensor(2), GetGTSensor(3), GetGTSensor(4));
The gear tooth sensors are plugged into ports 1 and 2.
Output:
1: 0 2: <port 1 output> 3: 0 4: <port 2 output>
If I invert instead:
StartGTSensor(1, -1);
StartGTSensor(2, -1);
then I see this:
1: -1 2: <port 1 output> 3: -1 4: <port 2 output>
Regards,
-scott
Unread 01-02-2008, 16:19
Originally Posted by scottanderson View Post
The problem is probably with the printf() statement, not with the Gear Tooth Sensor code. You're asking for four ints to be printed. It looks like GetGTSensor() returns a long. The first %d will show the first 16 bits of GetGTSensor(1), the second %d will show the rest of GetGTSensor(1), the third will show the first 16 bits of GetGTSensor(2), etc.
If this is the case, you can correct the problem either by printing the values using %ld, or by casting them as (int).
Unread 01-02-2008, 17:22
AKA: Scott Anderson
FRC #2608 (MiGHT)
Oh, jeez. For some reason I thought that function returned int.
Yes, that probably explains it. Thanks.
Regards,
-scott, who apparently has been programming in Java for far too long.
Gear Tooth Sensor marco_alchemy Electrical 7 06-02-2008 09:54
Gear Tooth Sensor Nathan Programming 4 12-01-2008 15:09
Gear Tooth Sensor? Raikon Kit & Additional Hardware 3 09-02-2007 16:40
Gear Tooth Sensor nukem Programming 9 04-02-2006 20:21
Gear Tooth Sensor Talha Electrical 1 23-01-2006 21:29
