Go to Post .. if everybody else is buying all the thingamabobs so they can practice shoving balls into the whatsit. Maybe what you really want is to buy thingys so you can build a practice whojidingle. Being the only whojidingle robot can be a real advantage come alliance picking time ... - ChrisH [more]
Unread 01-02-2008, 17:51
paulcd2000's Avatar
paulcd2000 paulcd2000 is offline
Accidentally speaks in C
AKA: Paul Dagnelie
FRC #1719 (The Umbrella Corp.)
paulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the rough
Send a message via AIM to paulcd2000
Unknown device id (0)
I know there's another thread for this, but since no one has been checking that, and I have new info, I'm posting here. Every time we try to load code, we get "Unknown Device Id (0)", and it also says "Invalid CTS Handshake".
We have already tried:
4 computers (not all windows)
3 USB-serial Cables
2 DB-9 Male-Female Serial Cable
2 RC's (07 and 08)
and more...
We've tried several different versions of code, including default code.
Does anybody have any ideas?
"People don't say 'It's just a game' when their team is winning!" -- Scott Adams
5.5 students (on average)* $7/h *210 hours/student= $8085 of labor, all volunteered (not counting mentors', who are each that much)
We have blades on our robot?! ***sweeeeeet***
There are 11 types of people in the world. Those who can read binary, those who can't, and those who say this joke is supposed to be, "There are 10 types of people in the world. Those who can read binary and those who have a life."
Unread 01-02-2008, 18:13
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: Unknown device id (0)
Email IFI.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 01-02-2008, 18:19
d235j d235j is offline
FRC #4454
d235j has a spectacular aura aboutd235j has a spectacular aura about
It's possible that your USB-Serial cables are causing problems. If possible, try connecting directly to a serial port.
Unread 01-02-2008, 21:52
CardcaptorRLH85's Avatar
CardcaptorRLH85 CardcaptorRLH85 is offline
The master of the cards ^_^
AKA: Raa'Shaun H.
FRC #0322 (F.I.R.E. "Flint Inspires Real Engineers")
CardcaptorRLH85 is an unknown quantity at this point
Send a message via ICQ to CardcaptorRLH85 Send a message via AIM to CardcaptorRLH85 Send a message via MSN to CardcaptorRLH85 Send a message via Yahoo to CardcaptorRLH85
I hope that when they change the interface next, that they consider using USB for the program connection. I've seen Serial-to-USB cables die for no reason whatsoever. Also I can't seem to easily find a new laptop with a serial port.
Unread 02-02-2008, 08:39
Originally Posted by CardcaptorRLH85 View Post
...I can't seem to easily find a new laptop with a serial port.
The answer to that problem is to find an old laptop. They're not expensive. In fact, I've bought two of them this year, for a grand total of $205. The "fast" one is used as the programming computer; the "slow" one (running Windows 98, yet) is dedicated to the dashboard at the moment.
Unread 02-02-2008, 10:40
paulcd2000's Avatar
AKA: Paul Dagnelie
Alright, so i have news. The good news is that we can load code onto the robot using the newest usb-serial cable. The bad news is that this was also the case with the first and second cable at the beginnings of their lives, and then they failed for no apparent reason. So while buying a new USB-serial cable seems to solve the problem temporarily, we can't just just buy a new usb-serial cable every couple weeks, especially if it fails at the competition. Is the only solution using an older laptop?
Unread 02-02-2008, 11:15
j_johnso j_johnso is offline
FRC #0226
j_johnso is on a distinguished road
As a note, if anyone is looking for a new laptop with a serial port, the Dell Latitude's do include a serial port. I would not suggest buying one of these specifically for programming, as it is overkill, but it is a good multipurpose laptop for the price. (The low end ones start at about $550.)
Unread 12-02-2008, 19:48
paulcd2000's Avatar
AKA: Paul Dagnelie
Talking Re: Unknown device id (0)
THE PROBLEM HAS BEEN SOLVED!!! To any teams who get this same problem: here is the solution: The USB connectors on these cables have very thin metal pins, and they are pushed into the insulation so they lose contact. Fixing the problem is just a matter of gently squeezing the flat side of the connector to increase the pressure on the pins once inserted.
More importantly, inserting them gently on the USB end and making sure that
the cable doesn't hang down (but runs across a flat surface near the laptop)
will prevent this from happening again.
Unknown Device ID(0) DavidGitz Control System 13 28-01-2008 20:28
FIRST Unknown irishninja General Forum 4 24-04-2006 08:45
IFI Loader:Unknown Device id (0) Tridelvior Programming 4 12-02-2004 16:57
