Go to Post Attempted to like Andrew's comment and then realized this wasn't Facebook :P - afowl [more]
Unread 01-02-2008, 19:11
Sam2197's Avatar
Sam2197 Sam2197 is offline
FRC #2197 (Las Pumas)
Team Role: Driver
Sam2197 will become famous soon enough
Peumatics or Motor?!?!?!?!
our team is undecided as whether to use pneumatics or a motor to raise and lower a arm. if it is best to do a motor which one would be recommended.
Unread 01-02-2008, 19:13
emo Sponge's Avatar
emo Sponge emo Sponge is offline
FRC #1726
emo Sponge will become famous soon enough
Re: Peumatics or Motor?!?!?!?!
if your arm sticks out you should use peumatics
if it does not use a motor
peumatics are not realy safe
Unread 01-02-2008, 19:18
Sam2197's Avatar
Team Role: Driver
well i think it would be best to control the position of the arm. so from my knowledge you cant stop a pneumatic cylinder halfway through its stroke
Unread 01-02-2008, 19:21
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
If it needs more than 2 positions, motors are far and away the best way to go. Most motors could be used for this, but the Fisher-price motors and van door motor have been used most in the past.
sponge, I'm not really sure why you are saying that pneumatics are not safe. Certantly, precautions must be taken, but why is a pneumatic arm any more dangerous than a motor powered arm, if they are moving with the same power.
Unread 01-02-2008, 19:24
Kind of depends on the arm, but pneumatics have two positions. I might try two pistons for three or maybe four positions, but I'd rather use a motor for anything more than two position.
Unread 01-02-2008, 19:27
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
What makes you think that motors are safer than pneumatics?
Both can generate a lot of force and a lot of momentum. Both can be made safe, and both can be very dangerous if used incorrectly.
To Sam2197,
both pneumatics and motors can be used equally effective. If you already have pneumatics in your design then adding a cylinder is far less weight than a gearbox and motor ... but if you dont have pneumatics already in your system then the compressor alone may weigh more than using a motor and gearbox.
In short ... it depends
Good luck and let us know what you used.
___________________
- Tennyson, Ulysses
Unread 01-02-2008, 19:31
Sam2197's Avatar
Team Role: Driver
currely i have two designs one using pneumatics and one without. i really think we will need more than just those two positions though so i think we will need a motor for this. thanks for the help everyone
Unread 01-02-2008, 19:33
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Multi-positioning a cylinder is very doable... team 375's bot was an excellent example of this last year. You can get sort of a "spongy" response from a piston that isn't at the end of its travel, but you can make it work.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 01-02-2008, 19:41
emo Sponge's Avatar
FRC #1726
our team has a peumatic catapult and it is very dangerous
if the air compresor became faulty it could set off the catapult and injure someone
before peace
comes terror
Unread 01-02-2008, 19:43
Sam2197's Avatar
Team Role: Driver
wow. i would love to know how to do that.. i do a lot with pneumatics on the side and dont know how to make it like that. the only thing about my design is that the arm at its lowest spot sits inside of the frame. so when its lowered we wouldnt reach the ball. anyone have a way to get around that so we can use pneumatics .
Unread 01-02-2008, 19:46
Joe G.'s Avatar
AKA: Josepher
Yes, but it would be just as dangerous if it was motor powered. Anyways, either way, proper precautions to limit the risk of injury should be taken.
Back to the arm, it sounds like you are not completely sure over whether it needs more than 2 positions. In this case, motors would probably be advantageous. If you are not sure, than that (correct me if I'm wrong) means that you are probably not sure what the third position would be. As others have said, using sensors/mechanical stops/multiple cylinders, it is definatly possible to have 3 or more pneumatic positions. However, it is much harder to make these positions variable. Motors will allow you to put the arm in any positon needed, with no tricky mechanical work.
If you are sure, then the simplest way to do it would probably be what EricH suggested:
http://www.putfile.com/pic.php?img=7596589
Unread 01-02-2008, 19:53
Sam2197's Avatar
Team Role: Driver
thanks so much to everyone. our team loves the K.I.S.S. principle. so guess motor it is. should be easy to gear it down. thanks
Unread 01-02-2008, 20:01
GGCO's Avatar
GGCO GGCO is offline
AKA: Grant
FRC #3357
GGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to behold
Send a message via AIM to GGCO
Is your team really going to use a pnumatic catapul?? I would just stick with an arm raised by motors.
Just my $.02
Unread 01-02-2008, 20:17
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
You can either buy a solenoid that has a center-off position, or you can use two of the kit valves in tandem. What you do is connect the exhausts from a double solenoid to the single solenoid. Then you use the double solenoid to choose which direction to go, and then use the single solenoid to control the position. If that doesn't make sense, I can sketch it up in Paint.
_
Unread 01-02-2008, 20:18
Sam2197's Avatar
Team Role: Driver
i think i get what you mean
White Paper Discuss: Approx. Motor Spec for Taigene Motor Joe Johnson Motors 2 22-01-2005 16:36
Is it okay to run one motor in a two motor transmission? NoodleKnight Technical Discussion 27 16-12-2004 07:16
External metal jacket on the Drill motor and FP motor, WHY? archiver 2001 3 24-06-2002 04:22
Drill Motor and FP Motor Shaft Diameters Andy Baker Motors 4 11-06-2001 20:12
External metal jacket on the Drill motor and FP motor, WHY? Dennis Hughes Technical Discussion 1 04-06-2001 11:59
