Go to Post Blasphemy! Everyone knows Mountain Dew is roboteer fuel. - Racer26 [more]
Unread 01-02-2008, 21:29
SuspectZero's Avatar
SuspectZero SuspectZero is offline
2254 Team President
FRC #2254 (Twisted Transistors)
SuspectZero is an unknown quantity at this point
Speed up the Taigene window motor?
hi, i was wondering if there is any way to speed up the Taigene window motor. we were planning on putting a tough box at the end of it but we might loose torque due to that (plus i have no idea how we are going to make that work ). does anyone else have ideas as to how we can speed this motor up?
Team 2254: Twisted Transistors
2007 FRC: Placed 18th in Regionals
2008 FRC: TBD
Unread 01-02-2008, 21:34
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Speed up the Taigene window motor?
The Toughbox is a reducing gearbox, so your output will actually come out 12.75 times slower. (Unless you're talking about attaching it to the Toughbox backwards, but that would indeed be pretty complicated.) Your best bet is to mount a large gear or sprocket on the shaft of the motor, and then a smaller one on your appendage. This will give you an increase in speed, with a corresponding decrease in torque.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 01-02-2008, 21:38
2254 Team President
0o0o0 did not know that, thanks for telling me jgannon. yea a big gear to a small gear would speed it up, but would we loose alot of torque (which is needed cause this will be lifting our arm, and possibly the ball, up and down)?
2008 FRC: TBD
Unread 01-02-2008, 21:41
Sam2197's Avatar
Sam2197 Sam2197 is offline
FRC #2197 (Las Pumas)
Team Role: Driver
Sam2197 will become famous soon enough
not sure of the specifics but it sounds that motor has a lot of torque as it is. so if you were to have the gear sizes close but the one smaller it should give you more speed while keeping the torque. but the faster you go the less power you have
Unread 01-02-2008, 21:49
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
So.... what you're saying is you want the motor to put out more energy than you put in?
Sorry, but a force * rate of motion is wattage, and wattage you can't gear to get more of. It's a trade off.
I would suggest you try the window motor 1:1 and see how it works for you (preferably mathematically before you go out and try it). Then figure out what you need to do gearing/motor wise.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Please help.....Taigene window motors team 2191 Motors 17 12-02-2008 16:18
Taigene Window Motor- Circut breaker CarpeNoctem Motors 2 30-01-2008 19:13
Taigene Window Motor Information CoupeSprinter Motors 4 29-01-2008 20:27
Taigene Window Motor Specs master_nickz General Forum 0 22-01-2008 15:53
are we allowed to control a window motor using a speed controller? Wstedtlogan Motors 1 19-02-2006 15:47
