Re: How many positions?
3 positions per side; one ball of each color will be on each side. Random locations are chosen by the field.
There are (Per alliance) 3 spots to put your robot. And then there are ~6 positions where your balls could be, One on your overpass, and one on the opposite overpass. Very technical to do automode on the other side of the field this year :\
thanks man, that helped me out.
I had to check the rules just to make sure of this:
|HOME STRETCH| |bot | bot| bot| |
#8
) I was answering this part Quote:
#9
The wall is angled there though, Which leads to one robot sticking out, and if they are 30 inches, it will be touching another robot, which they are not aloud to do.
#10
All it has to do is touch not be flush.
#11
Well, if you have the back of the robot flat against the angled wall, yeah. But "touching" to me sounds like it can be just a corner of the robot touching the wall, but the front of the robot is still facing the overpass (parallel).
#12
The robots may be touching either the wall in front of the driver's station or the diagonal wall in front of the Robocoach area, see <G15>. That gives quite a bit more width to play with, plus might start a speedy lap bot a little farther down the track. Only a corner of the 'bot needs to be in contact with the wall, it does not have to have one side flush. That was covered in Q&A pretty explicitly.
Steve |
#13
Ah, i thought it had to be flush against the wall, now i understand.
#14
Glad I could help
| how many vandoors? | Justin_302 | Motors | 8 | 08-03-2005 18:54 |
| How many SD teams in 05? | JP_1163 | FIRST-related Organizations | 0 | 01-10-2004 11:50 |
| How many teams.. | archiver | 1999 | 8 | 23-06-2002 22:53 |
