Go to Post But here's the beautiful thing about FIRST: you are supposed to make mistakes. - RunawayEngineer [more]
Unread 02-02-2008, 00:04
Re: PROGRAMMING PNEUMATICS
Originally Posted by Aarnat View Post
What if you wanted a Single Pole Double Throw switch to toggle up to extend a piston and toggle down to retract a piston?
You can toggle a piston with just an SPST since it has the two states you'd need, on/off (in/out for a piston).
But if you wanted to use a SPDT just pick a pair of pins from 2, 7, 10, or 14 and ground on 4 or 12.
Your code would decide what to do with that information.
Unread 02-02-2008, 00:44
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
you could either use a couple of resistors to imitate the function of the analog "wheel" (circular thing on top of joystick), or use two seperate binary button inputs.
when using the "wheel" remember to account for slight variance in values.
-Leav
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 02-02-2008, 07:55
Aarnat's Avatar
Aarnat Aarnat is offline
Senior Captain
AKA: Aaron
FRC #2199 (Robo-Lions)
Aarnat will become famous soon enoughAarnat will become famous soon enough
Thank you to Mark and Leav,
I think we will use a SPST switch to save pins and the "off" position is to retract the piston and the "ON" position is to exstend it.
Thanks!!!
programming the pneumatics Armando Programming 2 17-02-2007 21:47
Programming Pneumatics? itzrobz Programming 2 20-01-2007 00:30
Programming of Pneumatics Ben Piecuch Programming 3 18-02-2005 02:39
Pneumatics Programming KWalsh Programming 8 19-02-2004 09:17
Programming PBASIC for pneumatics archiver 2001 2 23-06-2002 23:58
