Go to Post I know it's hard to believe, but there actually IS life after FIRST. - jleibs [more]
Unread 01-02-2008, 20:42
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Peumatics or Motor?!?!?!?!
Originally Posted by emo Sponge View Post
if your arm sticks out you should use peumatics
if it does not use a motor
peumatics are not realy safe
our team has a peumatic catapult and it is very dangerous
if the air compresor became faulty it could set off the catapult and injure someone
Your team has posted some marvelous information about your robot, and how they are taking safety precautions. I think you'd better find out just what your team is doing before you criticize. Your posts do not present a good image for your team.
(since 2004)
Unread 01-02-2008, 21:13
emo Sponge's Avatar
emo Sponge emo Sponge is offline
FRC #1726
emo Sponge will become famous soon enough
Originally Posted by rocketperson44 View Post
Yes, but it would be just as dangerous if it was motor powered. Anyways, either way, proper precautions to limit the risk of injury should be taken.
Back to the arm, it sounds like you are not completely sure over whether it needs more than 2 positions. In this case, motors would probably be advantageous. If you are not sure, than that (correct me if I'm wrong) means that you are probably not sure what the third position would be. As others have said, using sensors/mechanical stops/multiple cylinders, it is definatly possible to have 3 or more pneumatic positions. However, it is much harder to make these positions variable. Motors will allow you to put the arm in any positon needed, with no tricky mechanical work.
If you are sure, then the simplest way to do it would probably be what EricH suggested:
http://www.putfile.com/pic.php?img=7596589
your totaly right about the precautions
before peace
comes terror
Unread 01-02-2008, 22:07
CCCP's Avatar
CCCP CCCP is offline
stanislav Sekacov
AKA: The Russian
FRC #1726 (N.E.R.D.S.)
CCCP will become famous soon enoughCCCP will become famous soon enough
go with the motors
Unread 01-02-2008, 23:04
M'gnad-knockah M'gnad-knockah is offline
FRC #1517
M'gnad-knockah is an unknown quantity at this point
the other downfall to pneumatics is the efficiency, pneumatics only have a 4% efficiency, which sucks because the compressor has to run, and waste battery power.
Unread 02-02-2008, 07:41
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
where did you get that number?
Unread 02-02-2008, 15:08
FRC #1517
its common knowledge
Unread 02-02-2008, 17:29
We don't know it here... Go look at the books again. (Or I know who to ask, when I am at competition.)
Unread 02-02-2008, 17:48
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Assuming this number is true, it needs more clarification. 4% efficiency in what sense? 4% of the potential in the compressed air is converted to kinetic in a moving cylinder? 4% of the electric potential to run the compressor is converted to potential stored in the tanks? 4% of the electric potential to run the compressor is converted to kinetic in a moving cylinder?
Unread 02-02-2008, 20:42
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Actually, without a citation and/or verifiable reference, it is nothing but a common made-up number. Sorry, but saying"pneumatics only have a 4% efficiency " is just not credible without providing more information to back up the statement. Facts are preferred over conjecture.
-dave
White Paper Discuss: Approx. Motor Spec for Taigene Motor Joe Johnson Motors 2 22-01-2005 16:36
Is it okay to run one motor in a two motor transmission? NoodleKnight Technical Discussion 27 16-12-2004 07:16
External metal jacket on the Drill motor and FP motor, WHY? archiver 2001 3 24-06-2002 04:22
Drill Motor and FP Motor Shaft Diameters Andy Baker Motors 4 11-06-2001 20:12
External metal jacket on the Drill motor and FP motor, WHY? Dennis Hughes Technical Discussion 1 04-06-2001 11:59
