Go to Post The way things generally work in cases like this is simple: if you know something, you can't say it. So keep in mind that if someone does say something, it usually means they don't know. - Alan Anderson [more]
Unread 02-02-2008, 10:53
comwiz7's Avatar
comwiz7 comwiz7 is offline
AKA: Joey
FRC #1323 (Madtown Robotics 1323)
comwiz7 will become famous soon enoughcomwiz7 will become famous soon enough
Send a message via MSN to comwiz7
pic: Our New Robot Frame
Unread 02-02-2008, 10:56
bloodknight2077's Avatar
bloodknight2077 bloodknight2077 is offline
FRC #2077
bloodknight2077 is an unknown quantity at this point
Thumbs up Re: pic: Our New Robot Frame
Nice robot design, but what if a ball lands on your electronics board??
I assume that there is more to this robot that isn't shown.
Unread 02-02-2008, 11:40
Mr MOE's Avatar Woodie Flowers Award
Mr MOE Mr MOE is offline
MOE 365 Team Coordinator
AKA: John Larock
None #0365 (Miracle Workerz)
Mr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond repute
Nice frame / Design.
I love the color!
MOE Celebrates 18 Years in FIRST this season!
2007 CMP Chairmans Award - thanks to all MOEboteers, past and present!
Unread 04-02-2008, 00:11
comwiz7's Avatar
AKA: Joey
Well, the arm isn't on there yet (obviously), but it will protect the electronics. Plus, since we are about 15 pounds underweight, we'll probably add a lexan cover to the electronics.
Unread 04-02-2008, 00:18
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
Wow I like the time your spent painting your robot--this year looks to be very competative in the area of nice looking robots.
How's your center of gravity?
Unread 04-02-2008, 00:27
comwiz7's Avatar
AKA: Joey
Well we didn't want to lose two days to powder coating, but they were doing it for free and now our robot is awesome looking so it was worth it. We spent countless hours designing this thing and trying to avoid making the same errors as last year. We drew up our robot in AutoCAD for the technical parts, and 3DS Max to show everybody ideas and center of gravity was our biggest problem. We moved things around until it worked. The only problem we have now is that if you accelerate too fast without the ball, it will pop a fatal wheely but I plan to code a limit to how fast it can accelerate. Still working out the method of doing that though.
The worst problem we had (and that is pictured) is that parts of the frame were warped while our newer welder was welding it. The front wheels are 1/4" off the ground. That's fixed now though.
Unread 04-02-2008, 00:30
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
That's a very common problem with welding structures, the welded area shrinks as it cools and warps the whole thing. Try welding auto body sheet metal some time if you want a real challenge
Unread 04-02-2008, 00:32
well if you put encoders on the wheels you can determine velocity by using a timer function and dividing the number of encoder ticks by the time. You can determine acceleration by dividing that number by time again. (this is getting very nasty in terms of math)
Perhaps the easiest way is to use the kit enclosed gyro or an accelerometer.
Unread 04-02-2008, 00:49
Aren_Hill's Avatar
Build Nifty Things
i love the powder coat, i don't like the COG at the moment but i'm pretty sure your battery and transmission are going down under that which will remedy that problem.
Our electrical guys would like that amount of accessibility lol
A guy who likes robots.
Unread 04-02-2008, 00:54
comwiz7's Avatar
AKA: Joey
The battery does remedy the problem. Plus the way the frame is set up, swapping the battery takes just a few seconds, as opposed to last year.
Unread 04-02-2008, 10:02
team1203 4life's Avatar
team1203 4life team1203 4life is offline
President
FRC #1203 (Pandemonium)
team1203 4life is a jewel in the roughteam1203 4life is a jewel in the roughteam1203 4life is a jewel in the rough
Send a message via AIM to team1203 4life
yeah that could end badly
love the design way to thinck out of the book
pic: 233 robot teaser, yep, theres our robot ; ) ducttapedude Extra Discussion 20 15-02-2007 22:02
pic: the start of our Extruded fiberglass frame falconmaster Extra Discussion 8 09-01-2007 08:54
Check Out Our New Custom Frame! brennerator Technical Discussion 27 20-12-2006 04:43
pic: Our new robot CD47-Bot Robot Showcase 3 20-01-2004 00:01
Our new robot Todd Lawless Rules/Strategy 14 09-01-2002 18:17
