Go to Post This is not an engineering design challenge, this is a project management and common sense challenge with engineering elements. Don't go out of your way to screw yourself. - PayneTrain [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 23:03
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
or even New K3... +random musings by Joe J.
Posted by Joe Johnson.   [PICTURE: SAME | NEW | HELP]
Posted on 2/6/2000 6:33 PM MST
In Reply to: Can't find 'the NEW K1' posted by Joe Johnson on 2/6/2000 5:34 PM MST:
Actually, I mis-typed. I meant a New K3.
Actually, I CAN find a New K3 in update #1 but it doesn't really impact ordering custom gears & sprockets:
K3. If a part appears on the Additional Hardware List, it does not need to be
purchased from Small Parts, Inc. (SPI) and does not count against the $425 limit
on parts from SPI.
This doesn't really address ordering non-Off-the-Shelf gears & sprockets.
If NASA made some sprockets from legal kit material (Stuff from Small Parts Inc, Stuff from the green & gray tubs, or stuff from the additional hardware list -- which by the way includes off-the-shelf sprockets, of course), then these would be legal.
Perhaps I am missing something, but I think that this is exactly what I wrote in my original reply to this thread.
By the way, what are these sprockets?
I have often thought that a sprocket with a taped hole in the middle (3/8-24 as I recall) that had a hub thickness that was just a bit wider than the length of the drill shaft would be an excellent thing for many rookie teams. They could just screw the sprocket on the shaft and use a washer and the left handed screw from Bosch Service Parts (Bosch Part Number -- at least as of 1997 when we purchased these screws -- 3603430505) to lock the sprocket to the shaft.
This would probably work well for many teams. There is still the problem of securely mounting the drill housing because this method depends on the drill itself for all the bearings for the drive shaft (not a good idea in my opinion), but this is probably a better method to attach to the drill's output shaft than most rookie teams come up with so how can I complain?
Enough already ;-)
Joe J.
[IMG] code is Off
NASA Summer High School Apprenticeship Program dlavery Career 5 17-07-2004 12:13
NASA Robotics for Research and Exploration Brandon Martus General Forum 0 05-09-2003 08:20
Exciting NASA Opportunity matt sorgenfrei General Forum 10 12-08-2003 15:24
St. Louis anyone? Jeremy_Mc Regional Competitions 8 07-02-2003 12:06
KSC Results archiver 2000 2 23-06-2002 22:19
