Go to Post NOOOOOOOOOOOOooooooo!!!!! I hate regolith. - apalrd [more]
Unread 02-02-2008, 09:48
Lakeeffect1674 Lakeeffect1674 is offline
FRC #1674
Lakeeffect1674 is an unknown quantity at this point
Default Code error?
I loaded the new 08 default code to the robot, but it won't respond to the controllers and it will not respond when I give it a value of 255.
I read kevins post about upgrading the software to use the new code, but that just helped me to beable to load it to the bot.
I also noticed he removed the printf code.
how did other teams get their bot going?
and can someone tell me if I can add printf and how?
I just tried to program autonomys and I found that I am able to control the pwm(s) with static statements such as:
pwm=255
Unread 02-02-2008, 12:44
paulcd2000's Avatar
paulcd2000 paulcd2000 is offline
Accidentally speaks in C
AKA: Paul Dagnelie
FRC #1719 (The Umbrella Corp.)
paulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the rough
Send a message via AIM to paulcd2000
Re: Default Code error?
in teleop.c, call:
Default_Routine();
that should set pwm01 to p1_y, pwm02 to p2_y, etc.
You can edit the function in ifi_code.c
Look in the forum for help for beginning programming, there are several threads in existence already
"People don't say 'It's just a game' when their team is winning!" -- Scott Adams
5.5 students (on average)* $7/h *210 hours/student= $8085 of labor, all volunteered (not counting mentors', who are each that much)
We have blades on our robot?! ***sweeeeeet***
There are 11 types of people in the world. Those who can read binary, those who can't, and those who say this joke is supposed to be, "There are 10 types of people in the world. Those who can read binary and those who have a life."
Unread 02-02-2008, 12:54
psy_wombats's Avatar
psy_wombats psy_wombats is offline
AKA: A. King
FRC #0467 (Duct Tape Bandits)
psy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura about
Printfs can be used in the code, just need to remember to end lines with \r\n to make sure you get a new line.
Unread 02-02-2008, 12:55
FRC #1674
Thanks for the reply,but does it matter where I put it?
I tried adding that code but I get an error
"Clean: Deleting intermediary and output files.
Clean: Done.
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "autonomous.c" -fo="autonomous.o" -k -mL -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Thread would not exit normally.
Could not read language tool output from pipe. (5)
A language-plugin exception occurred and was logged.
BUILD FAILED: Sat Feb 02 12:55:39 2008"
Unread 02-02-2008, 13:05
paulcd2000's Avatar
AKA: Paul Dagnelie
there are threads which tell you how to solve that. Use the search function to find them
Unread 02-02-2008, 13:15
FRC #1674
Yeah thats what I have been doing for a few hours now.
I looked under beginning programming I can't find anything.
What else should I search for, cause I don't even know what to call my problem?
Unread 02-02-2008, 13:16
AKA: A. King
As far as I know there's been maybe one thread about this... And it wasn't really resolved. At least I haven't heard of this before.
Anyway, what version of mcc18 are you using? The build commands are a bit weird, (the disabling of the removement of unreachable code, and all the other minuses), but it doesn't look like that is causing an issue. Does this error still occur even without a printf? As this looks like a compiler issue.
And by default code, do you mean the FIRST default code or Kevin Watson's code?
Unread 02-02-2008, 13:19
FRC #1674
I am using mcp18V 3.10 I think ( I read a post by kevin saying we needed to use it)
the default I am refering to is from kevin.
where can I get the FIRST default code? isn't it the same as kevins?
I commented out all printf because it didn't work and I just wanted to get the bot moving.
Unread 02-02-2008, 13:23
june_2008 june_2008 is offline
AKA: Julia Filer
FRC #0547 (Fear)
june_2008 is an unknown quantity at this point
Where did you get 2008 default code? I looked on ifirobotics.com and couldn't find anything newer than 2007. I also looked on kevin.org and didn't see anything there that looked like '08 default code.
- 2006 St. Louis Regional Champions
2006 Galileo Division Finalists
"Those parts of the system that you can hit with a hammer are called hardware; those program instructions that you can only curse at are called software."
Anonymous
Unread 02-02-2008, 13:25
FRC #1674
kevin.org/frc/
http://www.kevin.org/frc/ifi_frc_simple.zip
is there something else I should be using?
Unread 02-02-2008, 13:31
AKA: A. King
There really isn't a 2008 default code, so I suppose 'default' would be 2007's default code. The real difference is that it's only compatible with the 2.4 version, thus the topic title of the sticky. (Sorry, I'm not the most knowledgeable about the compiler...)
That looks right for Kevin's sensorless code, there are version available with the gyro and stuff, if you want it.
Unread 02-02-2008, 13:32
FRC #1674
would you recomend sticking with the 07 code?
Unread 02-02-2008, 14:06
AKA: A. King
I don't think you should abandon Kevin's code yet, it really is very handy. However, bulky code that works is better than elegant code that doesn't. I'd save this as a last attempt.
What version of MPLAB are you using? There might a problem there, try reinstalling with 8.0+ or something. (I don't know MPLAB well either, just a thought.) And looking at the build stuff again... Do you have the include search path at C:\mcc18-3.10\h or similar? That's set by right clicking the project, (.mcp), selecting Build Options and using the Directories tab.
Unread 02-02-2008, 14:08
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Clean: Done.
This is a very strange error. Are you using Windows? What version of MPLAB are you using (not C18, which is different)?
-Kevin
Kevin Watson
http://kevin.org
Unread 02-02-2008, 14:55
FRC #1674
We added mcc 18 to the search path and it still did not work. Also we are using MPLAB 8 with Windows.
Error in code light on, trouble finding error Bryan Herbst Programming 16 12-10-2007 21:59
Problems integrating CMUCAM code and IFI Default Code Windward Programming 2 06-02-2007 16:48
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
user code to default code phoenixomega001 Programming 5 09-01-2005 00:09
