Go to Post Yeah, if we didn't have robots then we could concentrate on all that outreach stuff! - marshall [more]
Unread 02-02-2008, 13:26
xrabohrok's Avatar
xrabohrok xrabohrok is offline
hunter of errors
FRC #1208 (The Metool Brigade)
xrabohrok is an unknown quantity at this point
Re: Relay program?
Where is this file in the overall scheme of the robot? I don't know how to look at easy C to intuitively know what is going on, but it could be you are calling the function in the wrong place. Is the function called in user_routines.c? It should probably called somewhere from within Default_Routines(). I am assuming the easy C version of the code is organized the same way as just regular code.
"It's programming's fault" may be a viable excuse for just about everything, except the robot falling apart.
It will 'cause it can!
constants aren't. variables won't.
Instance relay Team_486 Programming 0 28-03-2007 09:56
Relay Commands Matt Krass Programming 6 18-02-2006 23:03
Relay Assignments MulletFish Programming 9 27-01-2005 14:15
Relay fault archiver 2000 2 23-06-2002 23:36
Relay Outputs OddOne Technical Discussion 3 01-02-2002 19:52
