Go to Post I blame FIRST for being the best thing that has happened to me. - vivek16 [more]
Unread 02-02-2008, 11:48
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Recoil tubing?
Did the kit of parts come with recoil tubing this year?
I seem to remember it did, but the kit of part checklist and our inventory say otherwise. If it did not come with recoil tubing, can we get some?
Thanks!
Unread 02-02-2008, 13:32
Bob Steele's Avatar
AKA: Bob Steele
Re: Recoil tubing?
I hope your build is going well!!
I am assuming that when you say recoil tubing you are referring to coiled tubing.
The KOP had none of this. I honestly cannot remember ever having this in a KOP for the past few years or ever actually.
You can order it from Freelin Wade (http://www.freelin-wade.com/index.php)
They provided the tubing in the kit this year.
If you call them they can get you anything that you need.
They give a 50% discount on a single order from FIRST teams and are really great people to work with. You will have to call them to set this up though.
Just call them @ 888-373-9233 and tell them you are a FIRST team
They will get you set up with anything you need.
Our team needed a coiled array with six different tubes for use on our all pneumatic lift/claw and the are sending us one that has a working length of 12 feet...
Remember that you only can order one time and get the discount so figure out whatever you need and contact them and place your order.
As I said they are very nice people and will help you.
If you have a problem tell them what the problem is and they may be able to suggest an answer...
Good luck in your build!!!
Bob
Skunkworks
Unread 02-02-2008, 17:21
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: Recoil tubing?
In the past we have made our own by coiling the kit tubing around a pipe and heating it up, either in an oven (200 degrees) or with a heat gun. You have to be careful with this because if you heat the tubing too much it could collapse. Also over heating might make the tubing brittle, but that takes a LOT of overheating. We've been pretty succesful using this method.
Unread 02-02-2008, 17:42
Re: Recoil tubing?
Double-stranded, either 2007 or 2006 (maybe 2005), red/blue. It only came that one year. It is legal.
Unread 02-02-2008, 19:48
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
Re: Recoil tubing?
It came in the 2006 kit. It was my team's rookie year, and I remember it lying around the room because we weren't educated in the ways of pneumatics.
Pneumatic Tubing Magnechu Pneumatics 6 28-01-2008 21:44
Wire recoil reel DougW Electrical 2 21-05-2007 22:08
creating tubing fluffy Inventor 3 07-03-2007 22:05
pneumatic tubing Matt21q General Forum 1 19-02-2007 20:05
Tubing pfortunejr Technical Discussion 6 11-01-2002 08:10
