Go to Post I guess this means we have to work on becoming super-flexible and always be ready for our close-ups at robotics from now on? - Beth Sweet [more]
Unread 02-02-2008, 13:38
OMAR_567 OMAR_567 is offline
FRC #2595
OMAR_567 is an unknown quantity at this point
Programming Help- 2 Motor 2 joystick Drive System
Can someone help us use change the default code from a one joystick operation to a two joystick two motor drive system?
We will be using a tank drive system. We would like to see some sample code.
Unread 02-02-2008, 14:01
bronxbomber92 bronxbomber92 is offline
FRC #1551 (Grapes of Wrath)
bronxbomber92 is an unknown quantity at this point
Re: Programming Help- 2 Motor 2 joystick Drive System
Team 166 just posted some of there code, and it included two-joystick drive. May be worth checking out!
Unread 02-02-2008, 14:08
jacobhurwitz jacobhurwitz is offline
FRC #0449 (Blair Robot Project)
jacobhurwitz has a spectacular aura aboutjacobhurwitz has a spectacular aura aboutjacobhurwitz has a spectacular aura about
If you're using a tank drive, it's simple. Pretend the left motor is pwm01 and the right motor is pwm02. Call the left joystick p1_y and the right joystick p2_y (because y is the forwards-backwards direction). Then the code is simply:
pwm01 = p1_y;
pwm02 = p2_y;
Note: you may need 255-p1_y if the left motor moves backwards. Same goes for the right motor: 255-p2_y.
When both joysticks are forwards, both motors are forward and the robot goes forward. When both are back, the robot goes backwards. When one is forward and one is backwards, the motors move in opposite directions and the robot twists clockwise or counterclockwise.
Direct Drive Four Motor System Collin Fultz Technical Discussion 42 02-11-2006 12:03
1 Joystick Drive or yaniv Programming 3 19-01-2005 14:18
Drive System Animation Project help is needed Brian Lesser Technical Discussion 4 12-10-2004 17:09
Control System, Joystick mod? Jordan A. Technical Discussion 16 13-02-2002 02:29
Quick Start Guide - Drive System Help for Rookies Nuts4FIRST Technical Discussion 5 31-10-2001 14:42
