Go to Post I'm liking this. Programmers wont. But I will. :D - Rion Atkinson [more]
Unread 01-02-2008, 18:58
iwin2000 iwin2000 is offline
iwin2000 has a spectacular aura aboutiwin2000 has a spectacular aura about
Need Help with Sensitivity of Joysticks
I'm trying to decrease the maximum range of the joystick on the x-axis using EasyC because the robot turns too fast on the x-axis. I tried using arcade mode at first, but I don't see a way of limiting the joystick range or the PWM output via the Arcade function.
What I tried to do was limit the PWM input. As a test, instead of being 0 (Minimum output), it is now 77, and it is 177 as a maximum. I used the following code and it doesn't seem to work. Does anyone know how I can do this?
unsigned char Port1XAxis = 127;
while ( 1 )
OIToPWM ( Port1XAxis , 1 , 1 , 0 ) ;
if ( Port1XAxis <= 77 )
Port1XAxis = 77 ;
//SetPWM ( 2 , 177 ) ;
//SetPWM ( 1 , 177 ) ;
else if ( Port1XAxis >= 177 )
Port1XAxis = 177 ;
//SetPWM ( 2 , 77 ) ;
//SetPWM ( 1 , 77 ) ;
Arcade2 ( 1 , 2 , 0 , 0 , 2 , 1 , 1 , 1 ) ;
I know this code has some errors, but can someone help me figure out how to do something like this?
Thanks a lot.
Unread 01-02-2008, 19:14
JohnC's Avatar
JohnC JohnC is offline
my other name is nigel
FRC #0360 (360 Revolution)
JohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the rough
Send a message via AIM to JohnC
Re: Need Help with Sensitivity of Joysticks
We used this to scale our drive last year. The "Offset" is referring to how far the joystick's Y-axis potentiometer is from 127.
int Scale_Offset(int initialValue, double scaleFactor) {
	return ((double)(initialValue-127)/scaleFactor)+127;
In context, it looked like this:
pwm05 = Scale_Offset(p1_y,3.);
What place are we at? ... TODAI!
Unread 02-02-2008, 01:49
That's right and I actually tried to do a function like that, but I am using EasyC's 'Arcade 2-motor' function to be able to control all motors through one joystick and it doesn't seem to allow for any input like that.
In Arcade mode, Y-Axis movement indicates forward/reverse, and X-Axis indicates right/left, and what I want to do is limit the X-Axis max PWM to something to slow it down (maybe minimum value of 77 and max of 177).
Does anyone know if/how I can do this in EasyC?
Unread 02-02-2008, 13:36
xrabohrok's Avatar
xrabohrok xrabohrok is offline
hunter of errors
FRC #1208 (The Metool Brigade)
xrabohrok is an unknown quantity at this point
My team has been using a speacial sin curve array to tone down the sensitivity. It has kind of been a hand-me-down for four years now.
const rom unsigned char joystick_values[256] =  {
0,   0,   0,   0,   0,   0,   0,   0, // 0   - 7
0,   0,   0,   0,   0,   8,  16,  24, // 8   - 15
30,  36,  41,  45,  50,  53,  57,  60, // 16  - 23
63,  65,  68,  70,  72,  74,  76,  78, // 24  - 31
80,  81,  83,  84,  86,  87,  88,  89, // 32  - 39
90,  91,  92,  93,  94,  95,  96,  97, // 40  - 47
98,  98,  99, 100, 101, 101, 102, 102, // 48  - 55
103, 104, 104, 105, 105, 106, 106, 107, // 56  - 63
107, 108, 108, 109, 109, 110, 110, 110, // 64  - 71
111, 111, 112, 112, 112, 113, 113, 114, // 72  - 79
114, 114, 115, 115, 115, 116, 116, 116, // 80  - 87
117, 117, 117, 117, 118, 118, 118, 119, // 88  - 95
119, 119, 120, 120, 120, 120, 121, 121, // 96  - 103
121, 121, 122, 122, 122, 122, 123, 123, // 104 - 111
123, 124, 124, 124, 124, 125, 125, 125, // 112 - 119
125, 126, 126, 126, 126, 127, 127, 127, // 120 - 127
127, 127, 128, 128, 128, 128, 129, 129, // 128 - 135
129, 129, 130, 130, 130, 130, 131, 131, // 136 - 143
131, 132, 132, 132, 132, 133, 133, 133, // 144 - 151
133, 134, 134, 134, 134, 135, 135, 135, // 152 - 159
136, 136, 136, 137, 137, 137, 137, 138, // 160 - 167
138, 138, 139, 139, 139, 140, 140, 140, // 168 - 175
141, 141, 142, 142, 142, 143, 143, 144, // 176 - 183
144, 144, 145, 145, 146, 146, 147, 147, // 184 - 191
148, 148, 149, 149, 150, 150, 151, 152, // 192 - 199
152, 153, 153, 154, 155, 156, 156, 157, // 200 - 207
158, 159, 160, 161, 162, 163, 164, 165, // 208 - 215
166, 167, 168, 170, 171, 173, 174, 176, // 216 - 223
178, 180, 182, 184, 186, 189, 191, 194, // 224 - 231
197, 201, 204, 209, 213, 218, 224, 230, // 232 - 239
238, 246, 255, 255, 255, 255, 255, 255, // 240 - 247
255, 255, 255, 255, 255, 255, 255, 255  // 248 - 255
It's worked for us. Just put the array like this:
pwm_01 = joystick_values[p1_y];
Do this for all pwm's you want dampend. Hope it works.
As for limiting speed, I have no idea what the arguments of the Arcade function are. If set pwms are what you are using to change the pwm values, they are commented out (you probably know that already). You also have it set 177 on the 77 if statement and 77 on the 177 if statement. Would switching those two help?
"It's programming's fault" may be a viable excuse for just about everything, except the robot falling apart.
It will 'cause it can!
constants aren't. variables won't.
Unread 02-02-2008, 13:43
psy_wombats's Avatar
psy_wombats psy_wombats is offline
AKA: A. King
FRC #0467 (Duct Tape Bandits)
psy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura about
As far as joystick sensitivity goes, our team has been using this:
long ramping (unsigned char ramp)
    long answer = 0;
    answer =  ((long)ramp - 127);
    answer = ((answer) * (answer) * (answer));
    answer = ((answer) / (128 * 128));
    answer = (answer) + (127);
    return answer;
It's not a sine function, but cubic. You should be able to have max speed at full forward, but also have better control with lower values. Something like:
http://www.chiefdelphi.com/forums/at...9&d=1201127844
Unread 02-02-2008, 14:21
jacobhurwitz jacobhurwitz is offline
FRC #0449 (Blair Robot Project)
jacobhurwitz has a spectacular aura aboutjacobhurwitz has a spectacular aura aboutjacobhurwitz has a spectacular aura about
    long answer = 0;
    return answer;
We're using a quadratic function. The only problem is that x*x is always positive, so we defined an absolute value function and do x*abs(x).
Sensitivity Wheels - help please naor52 Programming 6 20-01-2006 09:13
Help with Joystick Axes and Sensitivity bglass Programming 6 06-02-2005 14:01
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
Need help with C++ Tton Programming 7 04-11-2003 19:15
Could use some help with joysticks . . . archiver 2001 5 23-06-2002 23:36
