Go to Post "FIRST, molding the future of America by inspiring children in the fields of science and technology....and eliminating playground dodgeball forever." - Andy Grady [more]
Unread 02-02-2008, 14:09
Philz20 Philz20 is offline
MGSH Coder
FRC #2526 (Team 2526)
Philz20 is an unknown quantity at this point
IR Remote Programming
I'm trying to clarify something. During hybrid mode, we are able to use the IR remote by RoboCoach right? If so, do I need to program my autonomous to recognize IR commands, or does having it in the user_routines.c file the correct way how to do it?
Philip Kirshbaum
Maple Grove Senior High
Head of Programming and Control Systems, Team 2526
Unread 02-02-2008, 14:12
jacobhurwitz jacobhurwitz is offline
FRC #0449 (Blair Robot Project)
jacobhurwitz has a spectacular aura aboutjacobhurwitz has a spectacular aura aboutjacobhurwitz has a spectacular aura about
Re: IR Remote Programming
After you train the IR board (see the manual for details), it's simple. The board uses four digital inputs, and each input is 1 if it's respective trained signal is being received, 0 otherwise.
I forget the exact digital input numbers, though, and I don't have our code right now. (It's in the hallway being tested.)
EDIT: Apparently, the digital input numbers are just the four digital inputs into which you plug the IR board.
Last edited by jacobhurwitz : 02-02-2008 at 14:16. Reason: talked to another programmer
Unread 02-02-2008, 14:19
MGSH Coder
I'm pretty sure you read my post wrong. The IR remote is programmed, but I am talking about the actual code as in C.
Philip Kirshbaum
Unread 02-02-2008, 14:22
If you connected the IR board to digital inputs 1-4, then in the code, you use: rc_dig_in01, rc_dig_in02, rc_dig_in03, rc_dig_in04. If the button that you trained first is pressed, rc_dig_in01 is 1. Otherwise, it's 0. The second button is rc_dig_in02, etc.
psy_wombats's Avatar
psy_wombats psy_wombats is offline
AKA: A. King
FRC #0467 (Duct Tape Bandits)
psy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura about
It would be understandable to misinterpret the first post, I'm not quite sure myself what you mean. If you want your autonomous to react to IR signals, then, yes, your autonomous code will have to change depending on that signal. I'd think a few IFs in the autonomous would suffice. But what exactly are you trying to say?
Unread 02-02-2008, 14:26
MGSH Coder
That's all I needed to know. My IR board code is currently in Default_Routine under user_routines.c, so from what I'm hearing, it needs to go under User_Autonomous_Code under user_routines_fast.c. Is that correct?
Edit: The PWM cables are currently conncected to the digital 15-18.
Philip Kirshbaum
Unread 02-02-2008, 14:27
AKA: A. King
That would be correct. Otherwise it would respond in teleoperated.
Unread 02-02-2008, 14:44
MGSH Coder
I'm having a huge programming error as I'm trying to do this right now. Please check the category User_Autonomous_code to see if I did something wrong. The error was the line "void Process_Data_From_Local_IO(void)" which I made no changes to.
* FILE NAME: user_routines_fast.c <FRC VERSION>
* DESCRIPTION:
* This file is where the user can add their custom code within the framework
* of the routines below.
* USAGE:
* You can either modify this file to fit your needs, or remove it from your
* project and replace it with a modified copy.
* OPTIONS: Interrupts are disabled and not used by default.
#include "ifi_aliases.h"
#include "ifi_default.h"
#include "ifi_utilities.h"
#include "user_routines.h"
#include "user_Serialdrv.h"
#include "gyro.h"
/*** DEFINE USER VARIABLES AND INITIALIZE THEM HERE ***/
int Timer=0;
char STAGE=INITIAL_FORWARD;
* FUNCTION NAME: InterruptVectorLow
* PURPOSE: Low priority interrupt vector
* CALLED FROM: nowhere by default
* ARGUMENTS: none
* RETURNS: void
* DO NOT MODIFY OR DELETE THIS FUNCTION
#pragma code InterruptVectorLow = LOW_INT_VECTOR
void InterruptVectorLow (void)
_asm
goto InterruptHandlerLow /*jump to interrupt routine*/
_endasm
* FUNCTION NAME: InterruptHandlerLow
* PURPOSE: Low priority interrupt handler
* If you want to use these external low priority interrupts or any of the
* peripheral interrupts then you must enable them in your initialization
* routine. Innovation First, Inc. will not provide support for using these
* interrupts, so be careful. There is great potential for glitchy code if good
* interrupt programming practices are not followed. Especially read p. 28 of
* the "MPLAB(R) C18 C Compiler User's Guide" for information on context saving.
* CALLED FROM: this file, InterruptVectorLow routine
* ARGUMENTS: none
* RETURNS: void
#pragma code
#pragma interruptlow InterruptHandlerLow save=PROD /* You may want to save additional symbols. */
void InterruptHandlerLow ()
unsigned char int_byte;
if (INTCON3bits.INT2IF && INTCON3bits.INT2IE) /* The INT2 pin is RB2/DIG I/O 1. */
INTCON3bits.INT2IF = 0;
else if (INTCON3bits.INT3IF && INTCON3bits.INT3IE) /* The INT3 pin is RB3/DIG I/O 2. */
INTCON3bits.INT3IF = 0;
else if (INTCONbits.RBIF && INTCONbits.RBIE) /* DIG I/O 3-6 (RB4, RB5, RB6, or RB7) changed. */
int_byte = PORTB; /* You must read or write to PORTB */
INTCONbits.RBIF = 0; /* and clear the interrupt flag */
} /* to clear the interrupt condition. */
else
CheckUartInts(); /* For Dynamic Debug Tool or buffered printf features. */
* FUNCTION NAME: User_Autonomous_Code
* PURPOSE: Execute user's code during autonomous robot operation.
* You should modify this routine by adding code which you wish to run in
* autonomous mode. It will be executed every program loop, and not
* wait for or use any data from the Operator Interface.
* CALLED FROM: main.c file, main() routine when in Autonomous mode
* ARGUMENTS: none
* RETURNS: void
void User_Autonomous_Code(void)
/* Initialize all PWMs and Relays when entering Autonomous mode, or else it
will be stuck with the last values mapped from the joysticks. Remember,
even when Disabled it is reading inputs from the Operator Interface.
pwm01 = pwm02 = pwm03 = pwm04 = pwm05 = pwm06 = pwm07 = pwm08 = 127;
pwm09 = pwm10 = pwm11 = pwm12 = pwm13 = pwm14 = pwm15 = pwm16 = 127;
relay1_fwd = relay1_rev = relay2_fwd = relay2_rev = 0;
relay3_fwd = relay3_rev = relay4_fwd = relay4_rev = 0;
relay5_fwd = relay5_rev = relay6_fwd = relay6_rev = 0;
relay7_fwd = relay7_rev = relay8_fwd = relay8_rev = 0;
Timer=0;
while (autonomous_mode) /* DO NOT CHANGE! */
if (statusflag.NEW_SPI_DATA) /* 26.2ms loop area */
Getdata(&rxdata); /* DO NOT DELETE, or you will be stuck here forever! */
/* Add your own autonomous code here. */
static char latch=0, IR_cmd=0;
unsigned char sensorReading;
//**** Check the IR Sensor for a new command
sensorReading = PORTJ>>4; // Combined digital inputs 15-18
if (latch == 1)
if (sensorReading == 0)
latch = 0; // Take only the 1st reading to avoid being caught by a half & half state of the IR sensor
else if (sensorReading != 0)
latch = 1;
if (sensorReading == 8) IR_cmd = 1;
else if (sensorReading == 4) IR_cmd = 4;
else if (sensorReading == 2) IR_cmd = 2;
else if (sensorReading == 1) IR_cmd = 3;
printf("IR_cmd = %d\r\n", IR_cmd);
switch(IR_cmd)
case 0:
break;
case 1:
pwm01 = 127;
pwm02 = 127;
break;
case 2:
pwm01 = 254;
pwm02 = 0;
break;
case 3:
pwm01 = 0;
pwm02 = 254;
break;
case 4:
pwm01 = 254;
pwm02 = 254;
if (user_display_mode != 0) /* User Mode is On */
User_Mode_byte = sensorReading; //Show on the OI digital display
Process_Gyro_Data(); /* Gyro ADC Update*/
switch (STAGE) {
case INITIAL_FORWARD:
if (Timer < 114) {
pwm01=pwm02=pwm03=pwm04=255;
} else {
STAGE=INITIAL_LEFT_TURN;
break;
case INITIAL_RIGHT_TURN:
if (Timer < 200) {
pwm01=pwm03=0;
pwm02=pwm04=255;
} else {
STAGE=FORWARD;
break;
case INITIAL_LEFT_TURN:
if (Timer < 25) {
pwm01=pwm03=255;
pwm02=pwm04=0;
} else {
//STAGE=FORWARD;
STAGE=0;
break;
case FORWARD:
if (Timer < 50) {
} else {
STAGE=BACKWARD;
break;
case BACKWARD:
if (Timer < 400) {
pwm01=pwm03=0;
pwm02=pwm04=0;
} else {
STAGE=FORWARD;
break;
default:
pwm01=pwm02=pwm03=pwm04=127;
break;
Generate_Pwms(pwm13,pwm14,pwm15,pwm16);
Putdata(&txdata); /* DO NOT DELETE, or you will get no PWM outputs! */
Timer++;
* FUNCTION NAME: Process_Data_From_Local_IO
* PURPOSE: Execute user's realtime code.
* You should modify this routine by adding code which you wish to run fast.
* It will be executed every program loop, and not wait for fresh data
* from the Operator Interface.
* ARGUMENTS: none
* RETURNS: void
/* Add code here that you want to be executed every program loop. */
* FUNCTION NAME: Serial_Char_Callback
* PURPOSE: Interrupt handler for the TTL_PORT.
* CALLED FROM: user_SerialDrv.c
* ARGUMENTS:
* Argument Type IO Description
* data unsigned char I Data received from the TTL_PORT
* RETURNS: void
void Serial_Char_Callback(unsigned char data)
/* Add code to handle incomming data (remember, interrupts are still active) */
Philip Kirshbaum
Unread 02-02-2008, 14:49
AKA: A. King
Check your braces over by the next function up, the void User_Autonomous_Code(void). The compiler errors aren't very helpdul with line numbers. I strongly suspect this is the case.
Unread 02-02-2008, 15:15
MGSH Coder
The braces were removed, but it's still giving me the syntax error.
Philip Kirshbaum
Unread 02-02-2008, 15:24
AKA: A. King
Alright, giving this code closer inspection. You need one more brace to close the random brace hovering below the /* Add your own autonomous code here */ line, not removing the braces at the bottom. Or just eliminate that brace. That should fix the problem. Indentation is a good thing!
Unread 02-02-2008, 19:02
Eric Finn's Avatar
Eric Finn Eric Finn is offline
FRC #0166 (Chop Shop)
Eric Finn has a spectacular aura aboutEric Finn has a spectacular aura about
Send a message via AIM to Eric Finn
To avoid this problem in the future, I suggest using an editor with brace/parenthesis highlighting and block collapsing, such as Notepad++, which supports C, among other languages.
It always takes longer than you expect, even when you take into account Hofstadter's Law.
--Hofstadter's Law
Remote sportman3333333 Control System 2 27-01-2008 12:41
Remote programming box Ben Englert Programming 4 23-02-2006 22:56
Remote Network Ryan F. IT / Communications 12 01-07-2004 15:06
Remote Remote Kickoff for Southern California ChrisH Southern California Regional Robotics Forum 0 05-01-2004 12:36
Remote Remote Kick off at University High School George1902 Off-Season Events 4 04-01-2004 21:05
