Go to Post ...SEARCH BEFORE YOU POST, and when you do post think twice before pressing the 'post' button. - Brandon Martus [more]
Unread 02-02-2008, 15:15
psy_wombats's Avatar
psy_wombats psy_wombats is offline
AKA: A. King
FRC #0467 (Duct Tape Bandits)
psy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura about
Re: Default Code error?
So this compiles correctly without printfs? Or has it never worked correctly? If it has been built successfully at some point, what edit exactly caused the error?
Unread 03-02-2008, 09:52
Lakeeffect1674 Lakeeffect1674 is offline
FRC #1674
Lakeeffect1674 is an unknown quantity at this point
WE FIXED IT!!!!
Thanks everyone for your help.
We didn't know where to put the Default_Routines(); but as you will see we found it was already there and in the right place.
If this is happening to anyone else here is what we did:
1) in MPLAB under build options we have:
-set our output directory
-include in search path= "c:\mcc18\h"
-Library searchpath ="c:\mcc18\lib"
-linker skript="c:\mc18\lkr"
2) in Kevins code in the file "teleop.c"
Make sure to find where it says:
void Teleop(void)
// enable this to use IFI's default robot code
//Default_Routine(); // located in ifi_code.c
// update the state of the LEDs on the operator interface
Update_OI_LEDs(); // located in ifi_code.c
and uncomment Default_Routine();
Thats all we had to do to get it to run the driving code.
Error in code light on, trouble finding error Bryan Herbst Programming 16 12-10-2007 21:59
Problems integrating CMUCAM code and IFI Default Code Windward Programming 2 06-02-2007 16:48
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
user code to default code phoenixomega001 Programming 5 09-01-2005 00:09
