Go to Post Polycord. It was used in all sorts of ball systems in 2009, and on some of the 2007 claws. It's not too hard to fuse together by hand with some heat and patience. - AustinSchuh [more]
Unread 02-02-2008, 15:19
SidneySalvo SidneySalvo is offline
FRC #1691
SidneySalvo is an unknown quantity at this point
Ir board problems
Ok, so here is our problem, we have the IR board hooked up to a power source (12v battery) and we have check that the voltage is making it to the board, but none of the lights are turning on. We have been pressing the button that is supposed to make it work but it doesn't change anything. Does the board need to be hooked up to anything other than the power source to work and train, or is there some other problem i don't know about yet?
The Universe is filled with magical things, patiently waiting for our wits to grow sharper.
Problems with IR Board Mark McLeod Sensors 79 16-02-2008 20:57
Lights in Joystick board or control board rcubes85 Control System 15 26-02-2005 23:40
Perf Board = BS2-IC Carrier Board? indieFan Electrical 2 16-09-2004 08:28
School Board Problems Matthew_H General Forum 47 16-03-2004 18:32
