Go to Post Do give credit to the mentors, because they make you who you are. - Arefin Bari [more]
Unread 02-02-2008, 13:01
paulcd2000's Avatar
paulcd2000 paulcd2000 is offline
Accidentally speaks in C
AKA: Paul Dagnelie
FRC #1719 (The Umbrella Corp.)
paulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the rough
Send a message via AIM to paulcd2000
gyro and accelerometer problems
Hey, we're using kevin's new 08 code (along with accelerometer we found on chiefdelphi), and when we disable the robot, it calibrates the gyro and the acceleromter. However, the gyro bias is -1, the rate is -21, and the angle never changes, even when we move the robot. Also, the accelerometer never yields any result but 0. Any ideas?
"People don't say 'It's just a game' when their team is winning!" -- Scott Adams
5.5 students (on average)* $7/h *210 hours/student= $8085 of labor, all volunteered (not counting mentors', who are each that much)
We have blades on our robot?! ***sweeeeeet***
There are 11 types of people in the world. Those who can read binary, those who can't, and those who say this joke is supposed to be, "There are 10 types of people in the world. Those who can read binary and those who have a life."
Unread 02-02-2008, 13:11
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: gyro and accelerometer problems
As far as the gyro goes, are you sure that the wires are connected to the pins labeled T, and not the ones labeled R? This has been a really common mistake for years.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 02-02-2008, 15:26
paulcd2000's Avatar
AKA: Paul Dagnelie
no, i'm certain that that's not the issue. They use the weirdest naming system...
Unread 02-02-2008, 16:07
Jared Russell's Avatar
Taking a year (mostly) off
Put in some printf's in the ADC interrupt handler to make sure the analog input is updating.
Also, did you do these?
1) The gyro's rate output is wired to one of the analog inputs
of your robot controller and gyro.h/#define GYRO_CHANNEL is
updated with the analog channel your gyro is attached to.
2) The source code files gyro.c and gyro.h must be added to
your project.
3) A #include statement for the gyro.h header file must be
included at the beginning of each source file that calls the
functions in gyro.c. The statement should look like this:
#include "gyro.h".
4) Initialize_Gyro() must be called from user_routines.c/
User_Initialization().
5) Process_Gyro_Data() must be called when the ADC software
generates an update. An example of how to do this can be found
in user_routines_fast.c/Process_Data_From_Local_IO(). If you
use the gyro during autonomous period, Process_Gyro_Data()
must also be called from User_Autonomous_Code().
6) You must select the gyro you're using from a list in gyro.h
and if needed, remove the // in front of its #define. If you're
using the gyro from the 2006 KOP, use the default ADXRS150
gyro.
7) The default angular unit is milliradians. If desired, this
can be changed to tenths of a degree by editing gyro.h
8) A gyro bias calculation must take place using the functions
Start_Gyro_Bias_Calc() & Stop_Gyro_Bias_Calc() described below.
This must be done several hundred milliseconds after the gyro
powers-up and is allowed to stabilize.
9) For optimal performance, you'll need to calibrate the gyro
scaling factor using the instructions above or those included
in gyro.h.
10) Follow the instructions found in adc_readme.txt for
installation instructions.
Unread 02-02-2008, 16:53
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Because printf() is a big chunk of code to execute in an ISR, it's probably better to just stuff an ASCII character directly into the serial port output queue, as described here.
-Kevin
Kevin Watson
http://kevin.org
Unread 03-02-2008, 12:09
paulcd2000's Avatar
AKA: Paul Dagnelie
OK! so! i think i figured out the problem! it was probably the combination of
A: the gyro being plugged into the wrong port (curse you electrical people!), and B: the fact that i hadn't called Process_Gyro_Data() from Disabled_Spin()
Unread 16-02-2008, 15:17
paulcd2000's Avatar
AKA: Paul Dagnelie
OK! so now it isn't working! I've called several print statements and writing chars. all the appropriate pieces get called, but the value of:
temp_gyro_rate = (int)Get_ADC_Result(GYRO_CHANNEL) - gyro_bias;
is always zero, even when we're turning the robot. i've ensured that the number of ADC channels is greater than the number of our channel.
the gyro rate is generally around 30 or -31, but jumps around between these, even though the robot is still during calibration, and these don't change when i'm rotating the robot
i'm completely stumped... could we need a new gyro?
Gyro/accelerometer/Gear tooth sensor sparrowkc Technical Discussion 2 11-01-2008 22:47
Gyro Autonomous Problems cprogrammer Programming 5 23-03-2007 14:28
Gyro/Accelerometer Drew Shapiro Programming 5 06-02-2006 22:44
accelerometer problems kjohnson Programming 3 02-02-2005 10:53
