Go to Post After all, each day is fresh with no mistakes in it [yet]. - atomikitten [more]
Unread 02-02-2008, 18:27
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Re: Powering the IR detector from +5V instead of 7+ V.
Dave, I would agree with that logic, and was surprised by the Q&A answer.
However <R55> reads as follows:
• The Robot Controller power feed must be protected with a 20A circuit breaker. No other electrical load can be connected to this breaker.
• Power feeds to custom circuits and additional electronics must be protected with a 20A circuit breaker.
So I intend to build a 'custom circuit' consisting of a 5v regulator, on a separate circuit. This will power the IR receiver, etc.
I think it is a mistake to power the IR circuit directly from a 20A circuit anyway. (A potential of 20A going through the ribbon cable) The 3 terminal external regulator will also limit the current.
Powering the IR Board aznzricex Electrical 1 31-01-2008 11:02
Powering the IR board Dan G. Electrical 3 23-01-2008 01:58
How to make the camera search the light instead of only follow when targeted? jesusescobar Programming 4 18-02-2007 16:56
Powering the RC Mr. Steve Control System 15 06-03-2005 23:21
Powering the RC Mr. Steve Electrical 15 06-03-2005 23:21
