Go to Post How many programmers does it take to change a light bulb? None. They'll just say it's a hardware problem. - crafty [more]
Unread 02-02-2008, 19:00
Hastypickle's Avatar
Hastypickle Hastypickle is offline
AKA: Nicholas
FRC #1703 (Rats)
Hastypickle is an unknown quantity at this point
Compresser Wiring Help
I need help in wiring the compresser and the pressure switch so it will work the way it is intended. Me and a few others on my team have a few different ideas on how to wire them but we don't know if any of them will work.
Thanks in advance.
Unread 02-02-2008, 19:09
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
Re: Compresser Wiring Help
You have to hook the pressure switch back to the Robot Controller. DO NOT HOOK IT IN SERIES WITH THE COMPRESSOR
Use a PWM Cable cut off the male end and wire the Ground and Signal Wires to the pressure switch (doesn't matter which terminal on the pressure switch). Then you can plug the female end into a digital input on the controller
For the Compressor hook it up to a Spike Relay
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Unread 02-02-2008, 19:12
AKA: Nicholas
FRC #1703 (Rats)
So
compressor > spike
and
pressure switch > digital in
Unread 02-02-2008, 19:16
Gamer930's Avatar
AKA: Justin
Originally Posted by Hastypickle View Post
So
compressor > spike
and
correct
Edit: Programming line: relayX_fwd = !rc_dig_inXX;
Replace X and XX with the port number
Help wiring potentiometer-to-Analog port kylehager Electrical 4 17-01-2008 17:28
HELP...Wiring Problem neslo89 Inventor 0 11-03-2006 09:16
HELP! We need pneumatic wiring help! BrittanyV Pneumatics 13 10-03-2006 09:26
Wiring issues, help needed halomaster69 Electrical 7 19-02-2005 14:21
Help wiring Line sensors magical hands Electrical 1 18-02-2004 10:17
