Go to Post Man, what's the point of teaser videos if nobody looks closely at them. - Knufire [more]
Unread 02-02-2008, 12:42
lopz056's Avatar
lopz056 lopz056 is offline
Chris Lopez
AKA: chris lopez
FRC #1388 (Eagle Robotics)
lopz056 is an unknown quantity at this point
bumper problem
our team has run into a little snag w/ our bumper design, all of the dimensions are set and the mounts are on the robot, but there is a shaft thats going to be sticking out of the robot just the slightest bit, but enough to be in the way of the bumpers, we were wondering if it was legal to cut a hole (2 1/4" diameter), becuase other wise were in trouble
"Victory goes to the player who makes the next-to-last mistake."
Unread 02-02-2008, 12:52
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: bumper problem
The rules laid out for standard bumpers are being enforced very strictly. Cutting holes in the plywood is not allowed. One option worth considering is creating two sections of bumper that go on either side of your protrusion.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 02-02-2008, 14:22
lopz056's Avatar
Chris Lopez
AKA: chris lopez
Re: bumper problem
are you absolutely sure, because there is nothing in the manual saying against it, im pretty sure you know what your talking about but i want to make absolutely sure because otherwise i have alot more work ahead of me
Unread 02-02-2008, 14:41
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Re: bumper problem
You can check with the official FRC GDC Q&A, but to this point everybody that's posed a similar problem has been met with the same answer: standard bumpers are standardized and standards have no exceptions. No altering the bumper design. Period. .
Hi!
Unread 02-02-2008, 14:44
65_Xero_Huskie's Avatar
65_Xero_Huskie 65_Xero_Huskie is offline
One T
AKA: Mat
65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute
Re: bumper problem
Yep, you must have 3/4 of your robot filled with a "Standard Bumper". There can be no modifications to the bumpers or they would not be "Standard" bumpers.
Just split up the bumper into two parts on that side and you will be fine
Min-Max to the Max!
Unread 02-02-2008, 14:45
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: bumper problem
Should be 2/3
Unread 02-02-2008, 16:06
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
Re: bumper problem
This may be a silly question. If the shaft is just sticking out just the slightest bit, why not just cut off the end of the shaft? If it is just sticking out, it must not be doing anything where it sticks out anyway.
Unread 02-02-2008, 16:20
lopz056's Avatar
Chris Lopez
AKA: chris lopez
Re: bumper problem
its not so much that the shaft is sticking out, the pillow blocks its in stick out of the frame of the robot about a quarter inch. thats whats getting in the way of the bumpers
Unread 02-02-2008, 16:28
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
Re: bumper problem
Is it still within the size requirements with that block sticking out? If it is, you could make standoffs to set the bumper away from the robot enough so it won't interfere with the block.
Unread 02-02-2008, 16:35
lopz056's Avatar
Chris Lopez
AKA: chris lopez
Re: bumper problem
the bumpers are already 3 1/2 inches out of the robot, i wish i had some extra room. i really dont want to have to divide the bumpers (one on the two sides of the robot), because weve already welded the mounts and "prettified" the frame, so were not doing anymore welding
Unread 02-02-2008, 16:49
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: bumper problem
Well it looks like you have quite a few options here.
1. Ask the Q&A to verify the comments that have been posted here, all previous bumper questions have outlawed any modifications to the standard bumper system as described in the manual and I don't think this would be any different, but you can definitely try.
2. Change the design of the protruding shaft/pillow block setup so it does not protrude from the frame.
3. If you still fit in the 28"x38" box with the protruding pillow block (which you must do anyway), then you can use standoffs as suggested by usbcd36 to mount the bumpers outside the protrusion. If your bumpers are more than 3.5" thick I would examine whether or not they were designed according to official specs as a 2.5" diameter pool noodle and a 1/4" sheet of plywood do not add up to near 3.5". Mounts for the bumpers that are attached to the robot do not count towards this 3.5" and must fit within the starting dimensions of 28"x38".
4. Suck it up and split the bumper.
Regardless of which option you choose to go with, hopefully your team uses this as a learning experience. All parts of the robot design must be considered from the very beginning. This goes for big things (size, weight etc.) as well as small (flag holder, bumpers, RC visibility).
Unread 02-02-2008, 19:09
ALIBI's Avatar
FRC #0141
Team Role: Parent
Re: bumper problem
We had something similar last year. We ended up with shaft collars on the outside of our pillow blocks to help with end play. We just mounted the bumpers over the collars/pillowblocks and everything worked fine. Ours did not stick as far as yours do. Our frame started out about 0.75 inches less than 28 inches so we had the room to do it. It sounds like from previous posts you may all ready be beyond the length/width requirements, I hope not. If you are not, the 3 1/2 inches would start at the end of your shaft. A couple of washers/spaces to give support bewteen the bumper and frame and you should be good to go.
Unread 02-02-2008, 21:00
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Re: bumper problem
This question was addressed in this Q&A system answer.
-dave
Unread 02-02-2008, 21:05
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Re: bumper problem
-dave
And I have just posted a very similar question to the Q&A system (only to find out seconds later that it had already been answered in a different subforum), for which I apologize to the GDC. I wish I could delete that question to alleviate the GDC on answering the same things over and over...
My bad!
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 02-02-2008, 21:32
Sam N.'s Avatar
Sam N. Sam N. is offline
FRC #1351 (TKO)
Sam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to behold
Send a message via AIM to Sam N.
Re: bumper problem
You'll be fine boring material out of your wood. Try to put yourself in a position where you don't have to make a through-hole in the wood. That will come off better to the inspectors.
Last year we had so many bolt heads sticking our of our chassis that we had to drill half-way through our plywood in order to allow the plywood to sit flush with the chassis metal.
Sam
Mitty Robotics Alumni
TKO 1351
Bumper Qs Woody1458 General Forum 13 29-01-2009 16:41
bumper coolguybigt Technical Discussion 4 27-02-2007 16:40
Bumper Attachment bLuEpHoEnIx Technical Discussion 12 18-02-2006 20:22
bumper customization? gondorf General Forum 20 01-02-2006 19:30
Bumper or No? WebWader125 Technical Discussion 19 11-01-2006 01:28
