Go to Post Let this be a hint to the hardware teams. Deliver that robot early and give the software and driving team time with the robot. IR3 has proven it can be done. - Doug Leppard [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 23:04
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Tips for adding weight to a proto
Posted by Nate Smith.
Other on team #66, GM Powertrain/Willow Run HS, from Eastern Michigan University and GM Powertrain.
Posted on 2/10/2000 12:51 PM MST
In Reply to: Re: Remember to WEIGH IT DOWN posted by Lora Knepper on 2/8/2000 4:14 PM MST:
Speaking from experience...if you're going to add weight to your machine, make sure to put it where it can be anchored securely. Also, try not to have any of the weight outside the footprint of your machine...if you hit something with your extra weight and it shifts that weight, who knows what it's going to hit?
Nate
[IMG] code is Off
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
Opinions of robot parts.... archiver 1999 4 23-06-2002 22:37
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
Controversy at the SCRRF Scrimmage -- opinions needed! ahecht Rules/Strategy 31 05-03-2002 20:43
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
