Go to Post sweet nectar thy name is Dew... - Trinora [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 23:04
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
NUMBER 16 WIRE
Posted by Donn Griffith.
Coach on team #343, HC-COP, from F.P. Hamilton Career Center and NASA Kennedy Space Center/Oconee Partnership.
Posted on 2/7/2000 5:39 PM MST
In figure 2.1 on page 6 of the competition manual states that the number 16 wire should be white.
Our question is: Is white the only color allowed or can other colors be used in place of white?
#0047 (ChiefDelphi)
Red MAY be okay, depends on use
Posted by Joe Johnson.   [PICTURE: SAME | NEW | HELP]
Posted on 2/7/2000 7:59 PM MST
In Reply to: NUMBER 16 WIRE posted by Donn Griffith on 2/7/2000 5:39 PM MST:
I think that you may be able to use Red 16 gauge as well if you are using it to conduct a constant 12V or 5V. I have copied the rule sections below.
By the way, of course, you can use 16 gauge Black wire also.
Joe J.
C4. The wire supplied in the Kit may be used to conduct electricity. Additional wire
may be used as long as it meets the gauge and insulation color requirements as
described in Section 2.
C22. All wires distributing power with a constant polarity (i.e. not a Relay Module or
Speed Controller output) must be color coded as follows:
 Use Red or White wire for +12 Vdc and +5 Vdc connections.
 Use Black wire for Ground connections.
Additional Hardware List:
Control System
Wire Proper gauge, color & insulated
[IMG] code is Off
Telephone wiring Lisa Rodriguez Chit-Chat 4 18-06-2003 00:22
Q&A Discuss: Ramp wire CD47-Bot Extra Discussion 2 06-01-2003 20:57
Drill Motor Connections archiver 2001 8 24-06-2002 00:49
Motor wire sizes Tim Skloss Motors 5 13-02-2002 07:44
WASH scouting fields Mike Soukup Scouting 0 04-02-2002 02:39
