Go to Post Okay, Okay, I officially apologize to the the entire country of Canada - Joe Johnson [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 23:04
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Lock it in and go!!!
Posted by nuts4first.
Engineer on team #340, GRR - Greater Rochester Robotics, from Churchville-Chili and Nortel Networks.
Posted on 2/7/2000 8:38 PM MST
We just finished testing our drive system and this works....
If you are looking for a quick and easy way to lock your drill gearbox in low or high gear try some O-rings. You'll need 2 per motor to get the correct width. They go in between the gears in the back half of the motor assembly case. I think we used 1-1/2 OD 1/8' wall.
Good luck. If you try it, let me know how you do with it.
-Team 340
#0047 (ChiefDelphi)
Re: Lock it in and go!!!
Posted by Thomas A. Frank.
Engineer on team #121, The Islanders/Rhode Warrior, from Middletown (RI) High School and Naval Undersea Warfare Center.
Posted on 2/8/2000 9:50 AM MST
In Reply to: Lock it in and go!!! posted by nuts4first on 2/7/2000 8:38 PM MST:
: If you are looking for a quick and easy way to lock your drill gearbox in low or high gear
Hello All;
We've found that to lock into high, you need a spacer (we use delrin) that is the full inside diameter of the housing and approx. 0.055 thick installed in the forward end of the gearbox. To lock into low, you need a spacer, again the full inside diameter, approx 0.187 thick installed in the aft end of the gearbox.
Tom Frank
#0047 (ChiefDelphi)
Posted by Nate Smith.
Other on team #66, GM Powertrain/Willow Run HS, from Eastern Michigan University and GM Powertrain.
Posted on 2/8/2000 8:42 PM MST
In Reply to: Re: Lock it in and go!!! posted by Thomas A. Frank on 2/8/2000 9:50 AM MST:
Lock it in? Why would you want to do that? =)
Nate
[IMG] code is Off
