Go to Post Fancy that, better robots winning matches... - DampRobot [more]
Unread 02-02-2008, 23:40
tanmaker
Posts: n/a
pic: Green Paint Bomb?
Unread 02-02-2008, 23:41
Hastypickle's Avatar
Hastypickle Hastypickle is offline
AKA: Nicholas
FRC #1703 (Rats)
Hastypickle is an unknown quantity at this point
Re: pic: Green Paint Bomb?
Our team used some of the green lights from last year on the bottem of our OI.
Unread 02-02-2008, 23:49
Andy L's Avatar
Andy L Andy L is offline
FRC #1458
Andy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud of
Send a message via AIM to Andy L
Is it the angle or are those 3" CIMs?
Unread 03-02-2008, 00:25
ZZII 527's Avatar
ZZII 527 ZZII 527 is offline
"Scale Electric Vehicle"
AKA: Shane Colton
FRC #0097
ZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond repute
Send a message via AIM to ZZII 527
Maybe I'm just going crazy, but are the wheels in the right corners?
MIT Mechanical Engineering
>> College Mentor, Team 97: Cambridge Rindge and Latin School with The Edgerton Center, MIT Mechanical Engineering, Bluefin Robotics, and Draper Laboratory
>> Alumnus, Team 527: Plainedge HS
Unread 03-02-2008, 00:29
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
That was my first thought... I'm definitely thinking those wheels are on backwards.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 03-02-2008, 00:30
They seem to be using the "O" configuration instead of the "X" configuration. Unless the other set of wheels is switched, they're fine.
Unread 03-02-2008, 00:43
Éowyn Éowyn is offline
no team ((no team))
Éowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to behold
Nice Borg chassis you have there.
Unread 03-02-2008, 01:13
CCCP's Avatar
CCCP CCCP is offline
stanislav Sekacov
AKA: The Russian
FRC #1726 (N.E.R.D.S.)
CCCP will become famous soon enoughCCCP will become famous soon enough
awsome chassis&lights
Unread 03-02-2008, 01:36
tanmaker
Posts: n/a
It must be the angle, they are in fact 2.5" CIM Motors. They are mounted to individual suspension assemblies
You are correct. This was the first configuration we've tried and they first one we saw online. We might switch them later if we have time.
Unread 03-02-2008, 19:48
monty1540's Avatar
monty1540 monty1540 is offline
College Student Mentor
AKA: Eric
FRC #1540 (The Flaming Chickens)
monty1540 is an unknown quantity at this point
Send a message via Yahoo to monty1540
I believe that the wheels are indeed mounted in the wrong orientation. The roller that contacts the ground (opposite of the ones we can see) is at 90 degrees to the ones visible on top. To avoid being spun in circles by other robots, the rollers which contact the ground must have their sub-axles (the roller axles) arranged in an O shape. The reason I suspect these are reversed is that we are looking at the top of the wheels and it looks like they are set up correctly, but if you follow the rollers around underneath you'll notice the roller axles are at 90 degrees from those on top that we can see. The issue with the current setup is that the robot has no rotational traction, if another robot were to hit the robot on a corner, it would spin around [relatively] freely with little or no ability for the driver to compensate. Along the same lines, you will also have trouble rotating in place using the drive motors.
-Eric
Current WPI Student and college mentor to 1540
1540:
2008 Portland Regional Winner
2008 Portland Regional Engineering Inspiration Award
2007 Pacific Northwest Regional Finalist
2007 Pacific Northwest Reigonal Chariman's Award
Unread 03-02-2008, 19:57
spartan058's Avatar
spartan058 spartan058 is offline
Safety Captain, Team 1517
AKA: J
FRC #1517 (P4)
spartan058 is an unknown quantity at this point
Cool Re: pic: Green Paint Bomb?
very nice. however it looks like it's nuclear powered though!
Unread 03-02-2008, 22:57
tanmaker
Posts: n/a
Thats not really an air compressor, its the nuclear reactor in disguise.
Unread 15-02-2008, 03:18
Waiakea12's Avatar
Waiakea12 Waiakea12 is offline
Biohazard (Mechanical/Spirit/Scout)
FRC #2024 (Kekoa O' Haaheo (WARROR PRIDE))
Waiakea12 is an unknown quantity at this point
I agree with "Andy L" on the CIMS, They do look like 3"ers. (but I guess it could just be a small bot...) Those are pretty sweet lights.
That compressor is mounted kinda high on the chassis (no offense intended)... On your bot does the compressor make more noise up there???
Ours has always been mounted closer to the ground.
Unread 15-02-2008, 14:12
tanmaker
Posts: n/a
The compressor barely makes any noise. It's now mounted to metal instead of wood, and cushioned by a couple rubber washers on each bolt so it's extremely quiet. This is our first year using pneumatics so we have had fun experimenting with them.
pic: Team 16 Bomb Squad 06' SnareDrummer37 Extra Discussion 10 04-04-2006 15:08
FAHA: Green Paint Ken Leung General Forum 7 09-03-2005 22:47
Concerns regarding the green paneling/green shirts Petey General Forum 127 15-01-2005 10:35
