Go to Post You hang for show; kick for dough. - Travis Hoffman [more]
Unread 03-02-2008, 00:01
Kilroy0846 Kilroy0846 is offline
FRC #2139
Kilroy0846 is an unknown quantity at this point
Calling functions from other documents
In MPLAB, how do I call functions from other files in a project?
Here is my code:
static int counter;
counter = Get_Encoder_3_Count();
And the Get_Encoder_3_Count() function is located in the file encoder.c
Here is the function code:
long Get_Encoder_3_Count(void)
	long count;
	INTCONbits.RBIE = 0;
	count = Encoder_3_Count;
	INTCONbits.RBIE = 1;
	return(count);
The error that I get is:
Error - could not find definition of symbol 'Get_Encoder_3_Count' in file 'V:\frc-code-2007-8722\FrcCode_2007_8722\user_routines.o'.
Unread 03-02-2008, 00:09
dcbrown dcbrown is offline
AKA: Bud
dcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud of
Re: Calling functions from other documents
declare the function reference as external to your source file.
extern long Get_Encoder_3_Count(void);
Unread 03-02-2008, 00:15
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
are you #include'ing?
Unread 03-02-2008, 00:19
FRC #2139
I have the both the files encoder.c and encoder.h included. I added the external identifier, but I still get the same error.
Here is my new code:
static int counter;
Unread 03-02-2008, 00:30
JohnC's Avatar
JohnC JohnC is offline
my other name is nigel
FRC #0360 (360 Revolution)
JohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the rough
Send a message via AIM to JohnC
If you're using more than one function from a file, you could just include that file's header file. Use quotes if it's not a library that comes with the compiler.
#include "myfile.h"
What place are we at? ... TODAI!
Unread 03-02-2008, 00:32
FRC #2139
I Have the code:
#include "encoder.h"
#include "encoder.c"
located at the top of the document
Unread 03-02-2008, 00:37
AKA: Bud
It sounds like you haven't set up the encoder stuff correctly. Not all the encoder code is enabled by default. If that's the case then that routine isn't being compiled - its being excluded because ENABLE_ENCODER_3 isn't defined.
There is an encoder_readme.txt file in the documentation directory and there is info in the encoder.h file. Is the ENABLE_ENCODER_3 line in .h un-commented?
Unread 03-02-2008, 01:14
Chaos in a Can Chaos in a Can is offline
Joel Spadin
FRC #1736 (Robot Casserole)
Chaos in a Can is an unknown quantity at this point
Send a message via MSN to Chaos in a Can
You don't need to include "encoder.c", and in fact, you probably shouldn't.
I don't think that's the problem, but if you include a .c file, you're probably going to get an error about something like multiple declarations of something.
The headers tells the file that a function exists somewhere in one of the .c files. The actual code for that function doesn't need to be in the same .c file the function is used in.
2006 Xerox Creativity Award
2007 General Motors Industrial Design Award
2008 Judges' Award
2009 Chrysler Team Spirit Award
Unread 03-02-2008, 11:56
Take a few steps back. Undo everything you've tried to do in order to make it work. Read the documentation (I think it's called encoder_readme.txt) that comes with the encoder software. Follow the steps (nine of them, if I recall correctly) to add the code to your project and configure it.
If it still doesn't work, let us know.
Unread 03-02-2008, 19:39
ShotgunNinja's Avatar
ShotgunNinja ShotgunNinja is offline
Programming Mentor, FRC 4247
AKA: Nicholas Iannone
FRC #4247 (CougarBOTS)
ShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the rough
Here is my code:
static int counter;
	long count;
	return(count);
The problem could be that you tried to return a 'long' (4 bytes) variable into an 'int' (2 bytes) holder. Let me know if that helps any.
Team #2970 Alum
Team #1652 Alum
2006: School Mascot for Team 1652
2007-2008: Programmer for Team 1652 (Robot Mafia)
2009: Programmer on Team 1652 (Robot Mafia), Programmer on Team 2970 (eSchool eBots)
2010-2016: Volunteer, Wisconsin Regional
2017: Programming Mentor, FRC 4247 (CougarBOTS, Obama SCTE, Milwaukee, WI)
Calling C functions from EasyC koenig3456 Programming 4 27-01-2006 16:03
How Do I Program My RC To Spot One wheel From Going faster than the other Kyle1010 Programming 5 12-01-2003 15:30
Stack height Poll (spawn from other thread) Andrew Rudolph Chit-Chat 5 07-01-2003 17:15
Legality Issues Regarding Gears From other vendors kilpatrick Rules/Strategy 1 17-02-2002 09:04
And once more from the top... GLORIA! GEFORCE 3! AND OTHER CARDS... Robby O 3D Animation and Competition 1 24-01-2002 20:12
