Go to Post Being professional means doing things right. Being gracious means doing the right thing. They complement each other perfectly. But I think we should remember to use GP as a guide for our own behavior, not as a yardstick to measure others' shortcomings. - Alan Anderson [more]
Unread 29-01-2008, 09:30
adamrw91 adamrw91 is offline
FRC #0701
adamrw91 is on a distinguished road
Zdepth
ok im trying to render out a z-depth pass for my render and the antialaising semms to be non existent on it. how do i bump it up? when i try to use it for Depth of feild the edges are all messed up because the lack of anti aliasing.
any help would be great.
Unread 30-01-2008, 19:11
BuddyB309's Avatar
BuddyB309 BuddyB309 is offline
I freaking love animating!!
AKA: Peter Casey
FRC #1625 (Winnovation)
Team Role: Animator
BuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond repute
Send a message via AIM to BuddyB309
Re: Zdepth
what are you trying to use z-depth for? If you have a third party, you should add a slight gausian blur to everything to make it more realistic
A.K.A Llama
check out my latest animations Appliance Night Out, Infant Intolerable, Fishing Like a Loony Tune, VVV Roadside Assistance
Life? I have a life. It is sitting at my computer and Animating. AND DRAWING!!! WEEEEEEE!!!!
Unread 30-01-2008, 23:46
FRC #0701
Re: Zdepth
well im using it for depth of feild. and thats a good idea to blur it.
but how do u increase the anti alliasing on a zdepth???
Unread 31-01-2008, 17:51
FRC #0701
Re: Zdepth
well i tried using the gausian blur on the zdepth pass and it didnt work the edges are all mussed up. any other ideas?
Unread 31-01-2008, 20:53
BuddyB309's Avatar
AKA: Peter Casey
Team Role: Animator
Re: Zdepth
You are suppose to use your z-depth pass for a mask for the blur channel. Then after you do that you hide the z-depth layer. Kind of like what you do to morph targets. Your z-depth will never look smooth because you are not suppose to see it in your animation.
A.K.A Llama
Unread 01-02-2008, 00:10
FRC #0701
Re: Zdepth
well yeah im doing that its just when i use itas a mask its not anti aliased so thesome of the eddges get blurred and some of them dont. its weird.
Unread 01-02-2008, 19:07
BuddyB309's Avatar
AKA: Peter Casey
Team Role: Animator
Re: Zdepth
it would help if I could see a photo of the final result, and the work station of the third party program so i can see how it is layed out. I want the effects control window open if you are using adobe after effects.
Explain to me how your are useing the z-depth. What filter are you putting on it, the more detailed you are the more i can help you
A.K.A Llama
Unread 01-02-2008, 20:30
FRC #0701
Re: Zdepth
could ya just direct me to a tutorial?
Unread 01-02-2008, 22:40
Sergio Sergio is offline
FRC #0011
Sergio will become famous soon enoughSergio will become famous soon enough
Re: Zdepth
ditto
Reading a post on ChiefDelphi: $0
Not agreeing with this post: $0
Getting negative rep points for posting your opinion: Priceless.
Unread 01-02-2008, 23:33
BuddyB309's Avatar
AKA: Peter Casey
Team Role: Animator
Re: Zdepth
Using z-depth in discreet combustion
Here you go fellas, 7 full pages on z-depth and using it in combustion
A.K.A Llama
Unread 02-02-2008, 00:57
FRC #0701
Re: Zdepth
well i sorta need it for after effects.
but thanks anyway.
Unread 02-02-2008, 22:05
BuddyB309's Avatar
AKA: Peter Casey
Team Role: Animator
Re: Zdepth
but thanks anyway.
Now after effects I can help you with. Apply the filter channel>set matte to the one recieveing the z-depth (aka the beauty pass). Choose the z-depth layer as your mask and change type from alpha to luminously. hide the z-depth layer in your composition. Now what you should have is some layer that is showing a little. This will be your blur layer, now blur it with a Gaussian blur. Invert your mask in the effects window and then put the same Beauty pass layer underneath the one with the blur. Fiddle around with it, if some of the blur is bleeding into the objects that are in the foreground, you need to render them as separate layers.
I'm glad you are realizing the full potential of layer rendering, Its not a hard thing to grasp once you figure out after effects. Stick with it and you can do some amazing quality work.
Some advice to you, after you made everything look all nice you need to dirty it up. Add an adjustment layer on top of every thing and add a slight Gaussian blur and some noise. This adds one more level of realisim, I don't know why but it just makes it look that much better. Glows, blurs, and noise make it real.
A.K.A Llama
Unread 03-02-2008, 00:43
FRC #0701
Re: Zdepth
OMG thank you!
that was short, percise and perfect.
im for ever in your debt.
lol
Unread 12-02-2008, 08:38
Testament-Doom's Avatar
Testament-Doom Testament-Doom is offline
The wanderer of all worlds.........
AKA: David Perrot
None #0555 (Team 555)
Testament-Doom is a jewel in the roughTestament-Doom is a jewel in the roughTestament-Doom is a jewel in the rough
Send a message via AIM to Testament-Doom Send a message via MSN to Testament-Doom Send a message via Yahoo to Testament-Doom
Re: Zdepth
Mmaaayyybbbeee it's because the default scanline renderer isn't really good with antialiasing techniques or something, and you have slight pixelated edges on your models and blurring diminishes them in a rudimentary way, eh?
I'm just taking a stab here BuddyB, lol.
Testament-Doom's 3D art (If you want to check it out) - http://testament-doom.deviantart.com
"It does not matter how easy or hard it was to create your art, but the end result that matters most." - Me.
