Go to Post (I'm sure that Dave is holding his breath for "welding with Jello".) - jgannon [more]
Unread 02-02-2008, 17:51
Lawry Goldstein Lawry Goldstein is offline
FRC #1525
Lawry Goldstein is an unknown quantity at this point
pic: A new End Mill from McMaster
Unread 02-02-2008, 17:53
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: pic: A new End Mill from McMaster
Next time you buy some new end mills, go for something without the TiN coating.
TiN is not a good coating for non ferrous metals. You'd do much better with TiCN. Absolutely avoid TiAlN or AlTiN for aluminum.
You should try some 3 flute carbide variable helix ZrN coated end mills. You can get them pretty cheap, and they cut like a dream on Al.
2001-2004: Team 100
2006-Present: Team 254
Unread 02-02-2008, 20:06
FRC #1525
All but 3 end mills we ordered had the TiCN coating, but some were not available, that is why we have two of the kind as shown in the picture with a TiN coating, and one smaller end mill as well that was a weird size.
From what (rather small) amount of experience I have TiN coated endmills cut better then uncoated on plastics, aluminum, steel, stainless steel, and wood. This makes it worth the $1-3 that the coating adds to the cost, so when TiCN is not available I find it an acceptable alternative. We also do need steel parts from time to time, so we need to keep at least a few low-helix, TiN coated endmills.
I'll be on the look out for those, any suggest for where to get them? I generally try and stay with 2 flute because they are always centercutting and they are hard for people to clog.
Unread 02-02-2008, 20:18
Cory's Avatar
AKA: Cory McBride
Try www.lakeshorecarbide.com
I ordered some of their 3 flute variable helix end mills for aluminum for use on a CNC mill, and they rock. They clear chips just as well as 2 flutes, but cut soooo smoothly, and leave perfectly formed chips and a great surface finish.
They're ~$35 for a 1/2" end mill which may be expensive depending on what kind of tooling youve been purchasing, but they're a great deal for us, since the previous 1/2" end mills I've been purchasing were ~$45 for 2 flute TiN coated carbide.
2001-2004: Team 100
Unread 02-02-2008, 23:59
FRC #1525
It’s cheaper then what we were buying last year, more expensive compared to most of what we bought this year.
Just wondering, what exactly is a 'variable helix'? On their site the end mills look to have a very consistent helix to them, I can't see such a subtle change to make any real difference.
Unread 03-02-2008, 00:51
Cory's Avatar
AKA: Cory McBride
Sorry, I made a typo. They're high helix, variable flute*. The variable flute really makes these things rock. Since they don't all meet in the center, it totally eliminates all resonance and harmonics. I've fed in excess of 200 inches per minute on our mill, and it just purrs. Same thing with extended length endmills. even side milling a 2" long part, with a 2.25" long endmill, there's no chatter whatsoever.
That same 1/2" end mill that's $35 from lakeshore is like $70-90 from Niagara, Hanita, SGS, etc.
2001-2004: Team 100
Unread 03-02-2008, 01:45
k4r3n2's Avatar
k4r3n2 k4r3n2 is offline
AKA: Karen
FRC #1525 (Warbots)
k4r3n2 is an unknown quantity at this point
I was going to comment about our huge McMaster order of end mills, but then I realized that YOU ARE FROM MY TEAM.
Also the minions will still manage to clog them
Unread 03-02-2008, 01:54
Laxphan1525's Avatar
Laxphan1525 Laxphan1525 is offline
AKA: Harrison
FRC #1525 (Warbots)
Laxphan1525 is an unknown quantity at this point
Not if they recieve proper training before gaining access to the bridgeport which classes will begin after the season by Lawrence who manages to manually machine parts better than our cnc mill. Not only are the parts better but they are done faster and he wastes less of our material. However i use the term cnc mill lightly and when i mean i mean lowest of the light. Our so called CNC mill is actually a micro mill and it fails to cut he simplest bolt hole patterns. Maybe one of these days i will post a picture to let the whole first robotics world what not to buy in terms of cnc mills because this thing is awful.
BTW lawrence i was kidding about the classes eventhough it's probaly a good idea.
Unread 03-02-2008, 20:44
k4r3n2's Avatar
AKA: Karen
FRC #1525 (Warbots)
Well...I don't know if it's the Mini Mill's fault as much as it is that we don't have the proper software...
Also apparently it's not even supposed to be used for aluminum in the first place.
But yes, Lawry is an awesome miller
pic: New Mill Boydean Extra Discussion 2 07-01-2008 12:38
New Sears 3 Axis Wood Mill skimoose Chit-Chat 2 26-12-2006 23:58
pic: my new mill colin340 Extra Discussion 16 10-10-2006 20:31
Saturday Delivery from McMaster-Carr Question Madison General Forum 3 03-02-2006 18:03
