Go to Post Remember to have fun! That's what the FIRST experience should be for you- a lot of fun while doing a lot of learning. - smurfgirl [more]
Unread 02-02-2008, 19:47
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
816's Robot as of 2/2/08
Yeah were almost done just need to mount the bumpers, re-drill the hole on our van door motor for th elevator and mount some lexan.
-Dustin Benedict
Unread 02-02-2008, 20:15
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
Re: 816's Robot as of 2/2/08
nice and simple, can you guys knock off the ball?
TR-X 145 of Norwich, NY: Student 2005-2008
Exploding Bacon 1902 of Winter Park, FL: Mentor 2009
US Navy Corpsman 2011-????
Unread 02-02-2008, 22:41
thefro526's Avatar
Mentor for Hire.
yeah we actually can either knock it off with the forks on the elevator or we drive under the overpass and put the elevator up and just push the ball off the top.
-Dustin Benedict
Unread 02-02-2008, 22:45
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
FRC #0842 (Falcon Robotics)
I like the tennis balls! We need some sort of plugs for the end of our picker-upper, and this thought never occured to me.
Looks like a nice reliable design. How quickly can you move the ball over the overpass?
Unread 02-02-2008, 23:06
thefro526's Avatar
Mentor for Hire.
I like the tennis balls too, A mentor on our team ordered some orange and blue balls from a school supplier. It takes about 10-12 seconds to move the ball up and about 20-30 seconds for a full hurdle. I might get some video up in the coming week maybe late monday or tuesday.
-Dustin Benedict
Unread 03-02-2008, 00:10
thefro526's Avatar
Mentor for Hire.
Some more specs:
2 Cims through the KOP gearbox
25:22 reduction
6" Wheels
~10FPS
Chain Powered Lift
Van Door Motor with a 1:1 Ratio
-Dustin Benedict
Unread 03-02-2008, 00:36
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Very nice gripper and elevator. I get this weird feeling, though, that an abrupt stop or a bump from behind when you're in the configuration in the first picture would send you over... does it feel tippy at all? Also, what's your distance from left tennis ball to rear right corner right now?
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 03-02-2008, 01:16
CCCP's Avatar
CCCP CCCP is offline
stanislav Sekacov
AKA: The Russian
FRC #1726 (N.E.R.D.S.)
CCCP will become famous soon enoughCCCP will become famous soon enough
very nice bot you got there
Unread 03-02-2008, 02:11
Dolan's Avatar
Dolan Dolan is offline
Dolan
AKA: Andy
FRC #1590 (RAMBOTS)
Dolan will become famous soon enough
Send a message via AIM to Dolan Send a message via MSN to Dolan Send a message via Yahoo to Dolan
my team had an idea like this one but we did not do but i wish we did
Unread 03-02-2008, 02:21
thefro526's Avatar
Mentor for Hire.
It's a bit tippy all the way up but only at high speeds which it wont be driven at. We also have a few pounds to spare and we may add up to 4 pounds of steel/lead weights down low and then 15 pounds of bumpers. From either tennis ball the the opposite rear is about 72-73 inches which is far under the 80 inch rule
-Dustin Benedict
Unread 03-02-2008, 12:26
chinckley chinckley is offline
Winner 2009 West Michigan District
FRC #1254 (Entropy)
chinckley is a name known to allchinckley is a name known to allchinckley is a name known to allchinckley is a name known to allchinckley is a name known to allchinckley is a name known to all
How are you hoisting your uprights? Are you using chain? If so, how are you doing it? Any pics available? We are having difficulties with ours and we can sure use some help. Yours sure looks wonderful. We have looked at webbing, cable, chain. We are not sure how to proceed.
Carolyn Hinckley
2009 West Michigan District Winner
Thanks to Team 216 and Team 1918
2009 Traverse City Semifinalist
Thanks to Team 1596 and Team 47
2009 Traverse City UL Safety Award Winners
Attending 2009: West Michigan, Traverse City, & State
Unread 03-02-2008, 12:54
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Some more specs:
25:22 reduction
6" Wheels
~10FPS
Chain Powered Lift
A respectful suggestion since you still have 2-ish weeks left. That's a really really long lift time, and the van door motors are rather low power. Why don't you look into using an extra CIM motor through a dewalt transmission as detailed in the Nothing but Dewalts whitepaper. If you need the hard to backdrive properties of the van door, you can always leave the anti-backdrive pins in the edwalt transmission. With proper gearing you could probably get your lift time down to 3-4 seconds.
Unread 03-02-2008, 13:29
FRC #1254 (Entropy)
Question Re: 816's Robot as of 2/2/08
Is 4 the limit of CIM motors you can use? If we already use 4 what other motor besides the Van Door would work, if any?
Unread 03-02-2008, 13:32
FP, RS550, Window, Globe are your other options. FP is pretty good for lifts and arms, and apparently the RS550 is similar to it.
Unread 03-02-2008, 13:36
Danny McC's Avatar
Danny McC Danny McC is offline
Taking one home in '09.
AKA: Danny McCanney
FRC #0816 (The WesTech Anomaly)
Danny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant future
Send a message via AIM to Danny McC Send a message via MSN to Danny McC
Thats a pretty sexy robot IMO. Lets just hope we can do as good as it looks =)
pic: 816's First Teaser thefro526 Extra Discussion 5 02-02-2008 19:56
pic: 233 robot teaser, yep, theres our robot ; ) ducttapedude Extra Discussion 20 15-02-2007 22:02
pic: Team 114 Real Robot Vs. Inventor Robot James114 Robot Showcase 3 18-02-2005 13:02
Can an a robot take a tetra from another robot in their allinace? Koko Ed Rules/Strategy 3 10-01-2005 23:01
Robot Gallery from the 2003 robot expostion in Tokyo, Japan Andrew Rudolph Chit-Chat 1 04-12-2003 15:22
